Leak
Old Mar 16, 2024 | 03:13 AM
rickbmac's Avatar
Leak
1972 Oldsmobile Cutlass
350
Th350
Transmission leaked at kickdown cable o-ring even when car was not running.
Leaked on floor and then stopped.
Is it possible that Transmission was overfull and kickdown rubber o-ring is bad?
Definitely Transmission fluid on stick abuve full when cold. No 100% sure if stick is correct as replaced without original.
Please Advise?
Thank you
Old Mar 16, 2024 | 04:51 AM
PatL's Avatar
350
Th350
Please Advise?
Thank you
This happened to me once, when I my car was sitting for a very long time in the garage (very slight incline towards the rear of the car). I read that some of the fluid can slowly drain out of the converter. When I drive the car routinely it does not happen. I will get around to replacing the speedometer gear o ring......
Old Mar 16, 2024 | 06:20 AM
rickbmac's Avatar
This happened after driving and from detent cable o-ring.
61olds88
Nov 29, 2023 09:26 AM
1983Olds98
Ninety-Eight
Jan 11, 2019 03:23 PM
snail
May 23, 2017 10:12 PM
1965cutlassragtop
Jun 27, 2011 06:27 PM
scrappie
Apr 9, 2008 05:17 PM
