Question RE TH400 fluid cooler lines
Old May 29, 2025 | 09:42 AM
acavagnaro's Avatar
1969 442 with Turbo 400. Has the 5/16" hard lines carrying fluid to-and-from the radiator. Long story, but I'm afraid I may have stripped the threads re-installing one of the lines into the 1/2-20 inverted flare fitting mounted in the trans case casting. How are these two hex fittings captured in the case casting (passenger side)? I'm assuming since they're a hex feature they're threaded in but maybe the hex is only there to assist with installation of the line fitting. Since I may have to remove/replace one of them, I'd like to know how it's captured in the cast housing so I don't risk a bigger problem by damaging something else just trying to get it out! Thanks in advance.
BTW, tried to upload a jpg of the fittings I'm talking about just for convenience and the system apparently doesn't want to allow it. Never had that problem before.
Old May 29, 2025 | 09:59 AM
The case is 1/4-18 NPSM straight thread and use a copper or PTFE washer
Old May 29, 2025 | 10:07 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Here are the replacements.
Old May 29, 2025 | 10:14 AM
HydraMatic's Avatar
Old May 29, 2025 | 10:28 AM
The 1973 and later transmissions used NPT thread at the case, the earlier ones are straight thread with a washer.
Old May 29, 2025 | 11:58 AM
acavagnaro's Avatar
awesome - thanks, guys!
Dave’s Holiday 55
Aug 31, 2023 04:28 PM
jimvbills
Jul 14, 2016 07:06 PM
atkinsom
Sep 27, 2011 08:00 PM
devmar07
May 14, 2010 09:23 AM
mkendall87
Oct 8, 2008 12:39 PM
