Clutch pedal bracket, different or the same as an automatic?
Old Feb 9, 2024 | 12:42 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Is it different. I am just figuring out all my TH350 to TKX parts needed. Thanks.
Old Feb 9, 2024 | 01:16 PM
VC455's Avatar
Barely Registered
When I changed to an M6 transmission, I replaced the entire automatic brake pedal and bracket with a bolt-in bracket that carried the brake and clutch pedals from a manual transmission car.
I found a document that may help, if you would like some advice from a veteran of this conversion.
Old Feb 9, 2024 | 03:39 PM
Yes, please.
Old Feb 9, 2024 | 03:50 PM
VC455's Avatar
Barely Registered
Here is the list of parts I used for conversion. Today, there are kits--and those may already give you many of these parts.
The list omits the seals around the stick, which I fabricated from Camaro parts I found in the junkyard.
I had some trouble with driveshaft angles, and I needed to create more clearance in the driveshaft tunnel to avoid clash under full rear spring compression.
I wanted a console, so I had to adapt one to fit; the stick came out 3" farther back from stock and I needed to change the wood-grain inserts and reposition the shifter surround. You may have more stick positioning options than I had in 2005.
Old Feb 9, 2024 | 05:44 PM
If you are asking about the bracket that the brake and clutch pedals hang from, yes that part is the same for both. Simply pull the pivot pin for the AT brake pedal and install the new clutch and brake pedals. Easy Peasy.
Old Feb 9, 2024 | 08:14 PM
Qwik71442's Avatar
Full-time Taxpayer
Trying to send pm. Please clear some of your inbox.
Old Feb 10, 2024 | 05:54 AM
I just saw that and erased few in there.
Old Feb 10, 2024 | 05:58 AM
Thanks Joe, was going to check it today. Good to know. Do the Chevelle pedals actually fit? One of the hydraulic kits actually come with a pedal but just the clutch for some reason. My goal is have a clutch easy on the street to use but grips like it should. My ex BIL had a 5 spd Mustang, the clutch was awful to use, so heavy, almost a two footer.
ThatsMe
Jul 22, 2022 01:50 PM
65-330
May 8, 2022 05:12 PM
Mikep442
Apr 12, 2014 05:22 PM
higgenslake
Jan 31, 2013 09:01 AM
Bunser
Brakes/Hydraulic Systems
Apr 7, 2010 02:27 AM
