Neutral safety switch
Old Aug 17, 2023 | 01:14 PM
kbdecatur's Avatar
Hello is there anyone with a dual gate shifter in a 70 cutlass that has a picture of the neutral safety switch OR where can I purchase one? I’ve been told that they are different from the standard shifter?
Old Aug 17, 2023 | 02:02 PM
Yes, different than the NSS for the regular shifter.
Here’s one source:
https://www.opgi.com/lamps-lenses/lamp-hardware/neutral-safety-back-up-switch/switch-neutral-safetybackup-1967-70-oldsmobile-c240673.html?gclid=EAIaIQobChMI5-SO88vkgAMVNwWtBh2SkwYKEAQYASABEgKbUvD_BwE
Old Aug 17, 2023 | 02:03 PM
4speed455's Avatar
If you’re not concerned with being factory correct you could use the column mounted nss. They were used for all column shift cars as well as 71/72 floor shift cars. I opted for that route when I converted from column shift to the standard console shifter as well as when I switched to dual gate.
Old Aug 17, 2023 | 02:08 PM
kbdecatur's Avatar
I can’t pull up the link.. Thanks
Old Aug 17, 2023 | 02:10 PM
Dang iPhone.
just search for “1970 Cutlass dual gate neutral safety switch” and you’ll find multiple sources and pictures.
Or copy all that stuff above and paste it into a search window.
Old Aug 17, 2023 | 02:12 PM
kbdecatur's Avatar
I’ve tried all day and came up empty.
Old Aug 17, 2023 | 02:24 PM
4speed455's Avatar
Fixed Ken’s link
https://www.opgi.com/lamps-lenses/la...SABEgKbUvD_BwE
Old Aug 17, 2023 | 02:30 PM
kbdecatur's Avatar
It says that one won’t work with dual gate shifter.😩
442dale
Apr 6, 2023 02:16 PM
richkidd24
Mar 31, 2018 07:10 PM
StickW31
Mar 18, 2014 04:53 AM
ARw30
Sep 22, 2013 08:23 PM
roy341
Jun 27, 2009 07:26 PM
