M20 drain and fill
Old Apr 21, 2025 | 05:14 AM
mattking's Avatar
M20 drain and fill
Does anyone have a good fluid extractor that they can recommend?
Also is it a good idea to go ahead and drill and tap the missing drain hole with my transmission in the car, or should I wait until I eventually have to remove it for some other reason, or should you not drill and tap the hole, after all it has made it 60 years why mess with the way GM designed it?
Old Apr 21, 2025 | 08:23 AM
BillK's Avatar
Most guys that I know go ahead and drill and tap it for the plug. I did the one in my Chevelle. GM designed it that way for only one reason ..... it was cheaper than drilling the hole and putting a plug in
I dont think the fluid extractors can get all of the crap out of the bottom of the case. I have not done one in a while but I always used to pour some diesel fuel or Kerosene in the fill hole to flush out the junk in the bottom.
Old Apr 21, 2025 | 08:52 AM
mattking's Avatar
Thanks,
I would like to get as much of the oil fluid out as possible. So I'll give it a shot. I need to make sure I have room to get to everything first
Old Apr 21, 2025 | 09:32 AM
Sugar Bear's Avatar
X2 on a fluid evacuator not getting everything off the bottom.
I wouldn't drill it if it is a concours level car though.
Consider a magnetic drain plug.
CleanCutt
May 22, 2022 04:46 AM
Jonathan67
Jun 21, 2016 07:29 PM
jruzziconi
Jul 14, 2014 12:01 AM
68oldscutlass
Drivetrain/Differentials
17
Mar 22, 2013 05:37 PM
leroycjr
May 14, 2012 03:44 AM
