'67 cutlass covnertible adding fluid
Old Jun 21, 2016 | 05:43 PM
Jonathan67's Avatar
Hi, I'm into year two of my cutlass adventure...
The top is sluggish and I'm hoping I can add some fluid to fix the issue myself. Any suggestions?
I'm thinking I can add auto/trans fluid.
From what I've read, I should lower the top and add auto/trans fluid by unscrewing the small bolt on the right side of the pump assembly in the trunk.
Any suggestions would be much appreciated, thanks...
Old Jun 21, 2016 | 06:12 PM
66luvr's Avatar
Correct.
Top in down, all the way down, position. Fill to level full of fill hole. Some have a threaded plug some have a rubber plug.
If you try to overfill you can expect something to blow.
I sort of thought the rubber fill plug was designed to be a place to blow out the overfill fluid so the lines nor cylinders took the hit. Makes a big mess to clean up in the trunk. Oh yeah, I did it, added fluid with top up before I learned better.
Old Jun 21, 2016 | 07:29 PM
Jonathan67's Avatar
Originally Posted by 66luvr
Correct.
Thanks a lot, will try that out...
Jonathan
navvet
46
Nov 15, 2025 01:23 PM
65f85
Suspension & Handling
Oct 16, 2009 10:13 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
BLESSEDBYGOD
Mar 15, 2009 06:32 AM
JSGD1966
Oct 30, 2007 01:39 PM
