'67 cutlass covnertible adding fluid
Old June 21st, 2016, 05:43 PM
Jonathan67's Avatar
Hi, I'm into year two of my cutlass adventure...
The top is sluggish and I'm hoping I can add some fluid to fix the issue myself. Any suggestions?
I'm thinking I can add auto/trans fluid.
From what I've read, I should lower the top and add auto/trans fluid by unscrewing the small bolt on the right side of the pump assembly in the trunk.
Any suggestions would be much appreciated, thanks...
Jonathan67 is offline
Old June 21st, 2016, 06:12 PM
66luvr's Avatar
Correct.
Top in down, all the way down, position. Fill to level full of fill hole. Some have a threaded plug some have a rubber plug.
If you try to overfill you can expect something to blow.
I sort of thought the rubber fill plug was designed to be a place to blow out the overfill fluid so the lines nor cylinders took the hit. Makes a big mess to clean up in the trunk. Oh yeah, I did it, added fluid with top up before I learned better.
66luvr is offline
Old June 21st, 2016, 07:29 PM
Jonathan67's Avatar
Originally Posted by 66luvr
Correct.
Thanks a lot, will try that out...
Jonathan
navvet
44
September 2nd, 2014 07:06 AM
65f85
Suspension & Handling
October 16th, 2009 10:13 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
BLESSEDBYGOD
March 15th, 2009 06:32 AM
JSGD1966
October 30th, 2007 01:39 PM
Quick Reply: '67 cutlass covnertible adding fluid
