200-4R Tail Stock Movement - Worn Bushing?
Old Jan 30, 2026 | 11:30 AM
Tuffnut's Avatar
I was under the car today inspecting doing routine maintenance and noticed I can move the driveshaft a bit coming out of the transmission. It’s not leaking oil at all from the seal. Is some movement acceptable? I notice it clunks when downshifting into first depending on my speed.
I don’t want to open up a can of worms for something that may be normal. I have no vibration when driving .
Jeff
Old Jan 30, 2026 | 12:14 PM
66_Jetstar's Avatar
It should be relatively tight. I have replaced that bushing before. It can be done without pulling the trans. There is a special puller for it, it took less than an hour to swap.
Old Jan 30, 2026 | 06:50 PM
Tuffnut's Avatar
Thanks for the info. I think I will buy one of those pullers and get a bronze bushing and a new seal. I like the idea of doing it in place.
Jeff
Old Jan 31, 2026 | 03:34 AM
66_Jetstar's Avatar
Its a good time to check out your yoke.. mine had developed some pitting and that caused the failure.
Old Jan 31, 2026 | 04:50 AM
Tuffnut's Avatar
I put new driveshaft in last year with a new yoke etc. I noticed the play then, I should have done something last year about it. May be a bit worse now. Hard to tell.
Jeff
67VistaBlue
Dec 5, 2025 03:07 PM
ben442
Aug 18, 2025 01:37 PM
bigdooly
Nov 21, 2021 07:28 AM
NMcCarthy
Nov 17, 2014 07:32 PM
at3reg98
Aug 17, 2013 10:59 PM
