69 4 speed linkage
Old Jan 15, 2024 | 06:29 PM
69oldsguy's Avatar
69 4 speed linkage
The shifter linkage for the '69 A bodies had a pin that held the 1-2 shift rod to the 1-2 bracket bolted to the selector fork. Does anyone know of a source for this pin? The linkage set I bought did not have the pin. The current linkage offered by all of the vendors does not use the clevis type of attachment. Thanks.
Old Jan 15, 2024 | 06:48 PM
66-3X2 442's Avatar
Just a normal pin used in a clevis. They are available from a hardware/Lowes/Home Depot/Ace etc.
Old Jan 15, 2024 | 07:45 PM
69oldsguy's Avatar
So it is a common size. That's great. I'll round one up then. Thanks.
Old Jan 15, 2024 | 08:16 PM
66-3X2 442's Avatar
They come in various lengths and you may have to cut to length but you should be able to find the right diameter.
Old Jan 16, 2024 | 05:23 PM
69oldsguy's Avatar
Looks like a 5/16 X 3/4 clevis pin is the correct size. As you said, available many places.
Old Jan 16, 2024 | 05:40 PM
66-3X2 442's Avatar
What are you doing for the anti rattle wave washer?
Old Jan 16, 2024 | 05:51 PM
69oldsguy's Avatar
I bought a pack of 20 from 5speeds.com so I've got that covered. Although, I'm not sure they will work on the clevis because it is cylindrical. It has a small flat front and back. It might work. Time will tell.
Old Jan 16, 2024 | 07:47 PM
66-3X2 442's Avatar
The wave/anti rattle washer goes on the inside of the end to keep it tight and not rattle or vibrate.
Old Jan 16, 2024 | 09:32 PM
69oldsguy's Avatar
Right, but if because of vibration the washer rotates to be in line with the cylindrical portion of the clevis, it will no longer be a spring but simply a shim. My wave washers have only one curve in them so it could conform to the clevis. But, we shall see.
GKranig1
May 31, 2023 12:20 PM
BSiegPaint
Aug 11, 2021 04:00 PM
My2nd 69 442
Nov 18, 2018 02:41 PM
67Rocket
Nov 24, 2016 07:59 PM
4424me
May 13, 2012 06:02 PM
