1948 Olds 76 hydramatic drive shaft seal
Old Nov 27, 2024 | 01:14 AM
papasmurf48's Avatar
Hi and greetings from down under ,can any of you learned people help me where to find a 48 hydramatic drive shaft seal
with a inner diameter of 38.1mm and outer 54.8. In Inches 1.5 inch inside 2.15 inch outside
most of the ones on eBay etc are larger .Any leads will help .Thanks Lou
Old Nov 27, 2024 | 02:55 AM
Tri-Carb's Avatar
Get a member here with 48 parts books to look up the part number. Your search will be easier,
Old Nov 27, 2024 | 03:57 AM
Did you check with Fatsco? They carry antique transmission parts.
https://www.fatsco.net/
Patmcg59
Sep 19, 2021 07:39 PM
rick442
Drivetrain/Differentials
Mar 6, 2019 05:22 AM
craftsmen22
Jul 30, 2014 05:47 AM
dc2x4drvr
May 2, 2011 11:10 AM
dynamic88
Aug 28, 2007 11:03 AM
