Drive shaft yoke
Old Mar 5, 2019 | 06:14 PM
rick442's Avatar
Drive shaft yoke
My rear transmission seal is leaking after replacing it. Does this distance look ok? I'm just wondering if it is too long and may be moving too much.
Old Mar 6, 2019 | 05:22 AM
SmirchIs#1's Avatar
What I have seen from taking apart and working on hundreds of muscle cars for 40+ years,the norm seems to be 3" of yoke engagement with the output shaft.If your yoke has 3.5" of useable surface,as many of the muscle cars had,then you're only in 1.5" which is not good.This will cause excessive ocilation at the "U" joint.This situation can cause a vibration and even cause the tail housing to brake on a hard launch.It will at least cause premature bushing wear.If this is coupled with a already worn bushing in the tail housing,then the seal could leak and the previous cond. described is greatly amplified.Also I notice there seams to be a lot of dirt or something present if the seal was just replaced.The seal and area must be clean,grease the seal groove and make sure the lip spring is in place.Careful when instaling
Oldssupreme
Aug 3, 2016 06:12 PM
davoaz
Aug 23, 2015 07:47 AM
craftsmen22
Drivetrain/Differentials
Jul 30, 2014 05:47 AM
jRoofgunner
Feb 18, 2014 07:12 AM
at3reg98
Jul 7, 2012 12:49 AM
