Leaking pinion seal at yoke
Old Sep 19, 2021 | 09:44 AM
Patmcg59's Avatar
About a month ago, I had a local company make me up a new drive shaft, at that time I also replaced the rear yoke on my 1971 Cutlass Supreme.
The only problem is, I didn't know that you needed to mark the yoke bolt, I know that now, too late....leaking oil from the seal.
I'm hoping someone can help me out here.... don't wanna f*** it up any more than I already did.
Thanks.
Old Sep 19, 2021 | 04:05 PM
67OAI's Avatar
Old(s)GuysRule
Unfortunately you will have to take it apart again to replace the seal, also at this time check the yoke to verify that the surface which contacts the seal is not damaged in any way. Now, the tough part; I'm sure you don't want to completely disassemble that rear end but how can you be sure to get the correct preload on the pinion bearing without replacing the crush sleeve. One way is to get a shim washer, about .005 to .010 inches thickness to provide that little more crush. Maybe others have another solution and will chime in.
Old Sep 19, 2021 | 04:56 PM
Patmcg59's Avatar
Thank you, sir.... appreciate it
Old Sep 19, 2021 | 07:39 PM
Sugar Bear's Avatar
How did you tighten the new yoke?
Sid
Drivetrain/Differentials
Apr 11, 2020 06:33 AM
rick442
Mar 6, 2019 05:22 AM
1965Jetstar
Jan 4, 2018 11:40 AM
tgilligan
Sep 24, 2017 06:04 AM
craftsmen22
Jul 30, 2014 05:47 AM
