Help replace rear end yoke seal 57 super 88
Old Mar 30, 2020 | 08:37 AM
Sid's Avatar
Sid
Yoke seal leaking on my 57 super 88, have any of you replaced the seal ? If so was it hard to get the yoke to brake lose, if so how did you remove ? What size is the nut holding the yoke on the shaft? , I have to replace the seal .Any information will be helpful.
Thanks -----------SID
Old Mar 30, 2020 | 09:10 AM
Sugar Bear's Avatar
Sid, I don't have experience on that vintage others will; but, which yoke? Trans/front or diff/rear?
Good luck!!!
Old Apr 1, 2020 | 09:57 AM
monzaz's Avatar
yoke seal replace
1 1/4" nut / socket
Drain the rear of oil
if it has been on for a long time you might want to pay to get it done.
Some how you will need to tap the yoke off the pinion snout splines.
pry the seal off DO NOT gouge the casting where the seal meets the casting or you will have leakage from there.
You will need a big diameter sleeve metal ring giant socket to drive the seal in square
try to keep the area from oil...(hard to do in the car)
coat the seal outer diameter with RTV sealant
drive it flush with the casting (keep it square)
lube the seal lip with oil
install yoke
tighten nut as much as you can with your hand wrench and lock tight.
after you think you got it on with NO in/out or up down play, only spinning
(you really should not be able to crush the sleeve with your hand tools your just not stong enough...IF by chance you do somehow over tighten with your hand you are in trouble)
You will have to redo a crush sleeve.
(this is all very doubtful)
Stake the nut into the thread with a point steel punch so it does not back out.)
You should be good.
THIS IS NOT THE TEXT book version.
The correct way is always to replace the crush sleeve. BUT I doubt you want to go there.... Entire rear tear down.
We do these seals on 8.5 12 bolt etc all the time and never have issues this way and is much more cost effective for the customer.
Jim
JD Race
Old Apr 6, 2020 | 04:20 PM
supmarjo's Avatar
Thnks mine doing the same ,waiting on the seal, found this info THNKS
Old Apr 11, 2020 | 06:33 AM
Sid's Avatar
Sid
Thanks for the information,------------------------------SID
rick442
Drivetrain/Differentials
Mar 6, 2019 05:22 AM
Oldssupreme
Aug 3, 2016 06:12 PM
craftsmen22
Jul 30, 2014 05:47 AM
jRoofgunner
Feb 18, 2014 07:12 AM
dynamic88
Mar 22, 2008 10:44 AM
