200r4 won’t shift out of reverse and now reverse too
Old Nov 28, 2024 | 06:47 PM
Jayeatwrld's Avatar
Tranny won’t shift out of first, and doesn’t go into reverse anymore either (did yesterday). I already checked the governor and it’s fine, replaced the filter and fluid and gaskets. I attempted to adjust the tv cable. If anyone could let me know that’d be awesome (SD Cali located if anyone’s local)
350 engine from cutlass, 200r4 tranny (in my omega)
Old Dec 10, 2024 | 06:50 PM
DR_DAN's Avatar
Before you go any further get a line pressure Guage and check pressures in PN4321 at idle. Then someone in the car holding the brake pedal sane test but disconnect and pull cable to full tv pressure and report back with findings
Old May 3, 2025 | 03:34 PM
gtucker's Avatar
gtucker
Sprag
Sprag broken rebuild time
Old May 3, 2025 | 09:37 PM
gs72's Avatar
72Cutlass S
agreed overdrive sprag is probably broken.
Old May 4, 2025 | 06:09 AM
There are several potential causes, nearly all of them require the trans to be rebuilt. On one of mine, which exhibited these same symptoms, the plastic thrust washer between the input drum shell and the lo/rev clutch housing had disintegrated, causing the two parts to weld together.
Old May 4, 2025 | 06:57 AM
Hopefully @Jayeatwrld comes back. He hasn't signed on in about 6 months.
Jayeatwrld
Nov 25, 2024 07:11 PM
Jayeatwrld
Nov 25, 2024 02:45 PM
1984_Delta88
Jan 28, 2022 12:03 PM
tom54tay
Apr 6, 2021 08:17 PM
Arrowstorm
May 20, 2014 05:23 PM
