73’ omega won’t shift into second gear (automatic)
Old Nov 25, 2024 | 12:10 PM
Jayeatwrld's Avatar
Hey guys, i need help figuring out why the car won’t shift, it only stays in first, and can go into reverse and neutral and park fine, the cable seems fine, but the fluid was near empty so I filled it up on a running engine, still won’t shift. Do I need to do anything else or what should I look for, thank you!
Old Nov 25, 2024 | 12:13 PM
Check the vacuum modulator and the attached vacuum line. Also check the kickdown, make sure it is not engaged.
Old Nov 25, 2024 | 12:21 PM
Sugar Bear's Avatar
Do you know what transmission it has?
Check as mentioned above and it may be stuck governor weights.
Get the fluid level precisely full warm.
Old Nov 25, 2024 | 12:22 PM
Jayeatwrld's Avatar
cool checking that now, I’ll update you what I find
Old Nov 25, 2024 | 12:23 PM
Jayeatwrld's Avatar
im not entirely sure i don’t even think it’s the original transmission. This one seems to have sensors, but I’m not really sure, and where are the governor weights?
Old Nov 25, 2024 | 12:24 PM
Be a TH 350, wouldn't it?
Old Nov 25, 2024 | 12:36 PM
Jayeatwrld's Avatar
Where’s the modulator going to be located?
Old Nov 25, 2024 | 02:45 PM
Jayeatwrld's Avatar
73’ omega Transmission won’t shift into second (auto)
Hey guys, i need help figuring out why the car won’t shift, it only stays in first, and can go into reverse and neutral and park fine, the cable seems fine, but the fluid was near empty so I filled it up on a running engine, still won’t shift. Do I need to do anything else or what should I look for. I already checked the kick down, it’s fine and adjusted, I can’t seem to find the vac modulator (I’m not sure it has one)
This is for the turbo hydra-matic 350 (according to the service manual)
thanks!
Old Nov 25, 2024 | 03:14 PM
The vacuum modulator is located at the rear of the trans, on the passenger side. Look for a round canister held in place by a bracket with a single bolt.
Old Nov 25, 2024 | 03:15 PM
There is no reason to start multiple threads for the same problem. The modulator is on the right rear of the transmission just above the pan with a vacuum line connected to it.
It looks like this
Turbo 350 Transmission Vacuum Modulator
Old Nov 25, 2024 | 07:11 PM
DR_DAN's Avatar
Pull the governor, I bet the plastic gear is stripped. Simple fix and it will cause it to stay in first gear
Garrett_Schmidt
Mar 18, 2022 10:14 AM
mother$hip89
Oct 24, 2021 08:29 PM
tom54tay
Apr 6, 2021 08:17 PM
Money72
23
Dec 24, 2019 07:32 AM
g_field07edd
Jul 27, 2018 06:35 AM
