- Which cam for my combo???
- Good oil pressure
- Car bogs on full throttle
- 350 rebuild
- Alum intake
- Using compressed air to hold valve in place
- 68-69 Quadrajet the same ?
- Pulling the heads on a 324 Rocket
- Where can I purchase gold paint for a 72' 350
- Horsepower and Torque???
- Should I Convert To Fuel Injection?
- Octane use in lead gas motor
- 350 intake manifold
- info about modification
- where is the best place to buy a parts
- Cutlass wont go over 25 miles per hour
- AC lines question
- windage tray
- 371 oil valley plugs
- Idle -stop solenoid
- Headers
- Header bolts
- 330 rear main seal
- which weight oil?
- Dip Stick Tube replacement
- Help me wake up my 305 in my 78 Salon
- 330 help
- Harmonic Balancer Seal
- OAI conversion question
- engine bay
- Quadrajet Float Level Adjustment
- no power
- 403 build
- 350 bolt up to jetaway?
- 72 350 Rocket for Chevy
- Gas pouring out of carb
- oil pan gasket
- New to the car need some help
- Disc Brakes and proper vacuum
- Edelbrock Heads in way of pump
- 71 350ci
- 1969 350 Camshaft
- Flattop Pistons with #7 Heads????
- expected horsepower gains
- Radiator
- Correct Fuel Filter?
- Intake manifold
- Proper coolant mix
- Aluminum intake
- Heads
- 330 what plugs?
- Leaking fuel at carb
- Hydraulic Lifter Preload on a 350
- Carb Recommendation for newbe
- Rebuilding a 350
- 350 pistons
- carb
- Chevy into Olds
- firing order quetion
- Edelbrock on a 303 or 324
- hey dipstick!
- Edelbrock Carb Vacuum Lines
- Rods and Caps
- Hi there got a question
- Eibach Lowering Springs
- Overheated! : (
- GUYS I NEED YOUR HELP!!!
- Starters
- remanufactured.com rebuilds?
- Exhaust Manifold help
- What year is my engine?!?
- 403 Factory Engine color
- Timing problem?
- squeaky belt
- Spoiler Installation Question
- READ THIS GUYS!!! What a shame!!
- Interchange of 260 manual transmission parts?
- Fuel pump replacement
- whats a good year to snach a 350?
- Spark plug gap
- Is this a ok install carb and intake combo?
- 371 cu. in. - some schooling needed
- Eddies Performance Motors? Is 7200 to much?
- 350 heads
- a/c brackets
- 207 3.4L Question
- oldsmobile 307 oil problem
- Thermostat Question
- 330 pistons
- Leak at oil plug
- more power for my 403
- Block number appears to be blank
- Engine swap
- Timing question on 54 Olds
- test
- another newb question
- heater control valve help on new intake
- Exhaust Leak
- Car wants to stall when in gear and idling
- Fan shroud
- Unknown antifreeze leak
- carb problem
- 45 degree cam in 350 ?
- Radiator Question
- Head Identification question..
- 71 cutlass small block
- '72 air cleaner
- Compressed air from oil filler tube
- Wiper/washer pump
- 77cc Cylinder Heads
- 70w-31 intake
- Fix for Edelbrock Clearance Problem
- running lean
- Loss of power
- Another Timing Question
- Heater
- rough idle
- Vacuum line diagram
- Well, Here it is!
- intake swap
- Iron intake on 307?
- update
- HEADER POBLEM holding up my car completion
- Timing pointer
- 350 head gaskets
- 1968 Olds 350 Rocket redline
- Building a Small block
- Ram Rod 350
- 70 olds 350 burning oil
- 371 performance
- Hedder fitment problem.
- timing
- hard to start cutlass supreme
- 350 olds into a 59 super 88
- valve spring lift
- Kinda bummed out
- vaccuum advance position
