White smoke from air intake
Old May 8, 2023 | 12:31 PM
ProfVanNostrand's Avatar
1969 Cutlass Supreme, 350ci.
What could cause white smoke to come out of the end of the air intake after shutting the vehicle off? Prior to shutting the vehicle off, it was only idling and putting around my driveway for maybe 20 minutes.
Old May 8, 2023 | 01:23 PM
442Harv's Avatar
Did it make a small back fire, or kick back? If so, probably some exhaust back through the carb?
Old May 8, 2023 | 01:40 PM
I did not hear anything abnormal when I shut the engine off.
Old May 8, 2023 | 02:14 PM
You may be running rich due to a number of reasons to include the carb needing a rebuild. It could also be blowby flowing out of the valve cover breather into the air filter housing.
Old May 8, 2023 | 02:43 PM
Okay. I will run it again and pull the air intake off to try to pinpoint where it is coming from.
Gerald Nickels
Mar 12, 2022 09:24 PM
Alg
Jun 25, 2017 09:27 PM
jimmymtfan19
Feb 27, 2017 03:34 PM
mrjarret1121
Dec 26, 2015 10:14 PM
olds4life
Jul 12, 2008 05:57 PM
