Air gap intake
Old Feb 23, 2017 | 05:29 PM
jimmymtfan19's Avatar
Air gap intake
Will an air gap intake fit a stock cutlass hood?
Old Feb 23, 2017 | 06:17 PM
RetroRanger's Avatar
72 Olds CS
IDK but what year cutlass will be helpful for sure.
Old Feb 23, 2017 | 07:16 PM
1970. 455
Old Feb 24, 2017 | 04:59 AM
cutlassefi's Avatar
Why are you wanting to use an air gap? What's your combination?
Old Feb 24, 2017 | 12:48 PM
12:5:1 461 aluminum heads e85. Long tubes. Th350 2800 stall. 522 544 cam 232 244 duration 107 110 lsa
Old Feb 24, 2017 | 02:23 PM
cutlassefi's Avatar
I'd use a Torker or even the "Shootout" intake from Procomp.
Jmo.
Old Feb 26, 2017 | 01:18 PM
Main thing is i want to consider what fits and doesnt fiy under stock hood. I think stock intakr carb pad height is like 5" the air gap and shootout ect. Are more like 6.5-7" also was wondering ig singlr plane vs dual plane is noticeable on notmal dtiving? I had an air gap i ran on a 355 and i noticed a diff after swap ftom stock cast iron.
Old Feb 26, 2017 | 02:03 PM
cutlassefi's Avatar
A 355 Olds? If so then I'm confused, they don't make an air gap for a small block.
And unless you have a fair amount of gear etc a dual plane is a better choice.
Old Feb 26, 2017 | 03:06 PM
Chevy 355
Old Feb 26, 2017 | 06:02 PM
z11375ss's Avatar
Senior Moment Member
I ran one on a 455 in a 68 Cutlass. It fit. Look this one up on here. it has been back and forthed ad nauseum.
Old Feb 26, 2017 | 07:54 PM
Nickyloves442s's Avatar
I read in one of the 455 engine buildups a few years ago, that an air gap hurt performance vs a single plain torker . something about the same velocity in both intakes, but it took the airgap longer to move the air than the torker. Cost about 15 horsepower. In essence, the way that the 455s are, if you use the full valley pan style intake gasket, it helps defer oil splash and heat a little anyway.
Old Feb 27, 2017 | 02:56 PM
Alright so torquer vs performer vs victor jr intake by nondello. They can machine it to fit under stockhood
Old Feb 27, 2017 | 03:34 PM
Im stuck on mondello posiflow or torquer both with the cone and port matched.
Bad68442
Nov 29, 2013 07:53 PM
70F85
Sep 22, 2013 08:22 AM
Finn5033
Feb 13, 2013 03:35 PM
Delmont 88 PA
Oct 30, 2012 06:08 PM
Delmont 88 PA
Jul 19, 2012 04:43 PM
