Vacume advance can
Old Apr 17, 2023 | 07:16 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Vacume advance can
Ok so this is hard to explain, I think my vacume advance is bad but not sure.
I usually make sure it has ported vacume. meaning when you give the carb alittle gas then it sucks the advance and pulls timing.
so that is working. but i have a Tiny dead spot. I just put in a New accelerator pump because that was bad also.
i had No fuel in the morning as the pump fell apart inside the carb so i fixed that and works fine.
so it seems that the vacume can some times pulls vaucme and some times it does not.
I do have the Tcs switch disconnected. i think that is what its called that can on the intake on the passenger front. that shouldn't matter those never work so i ran it direct to the ported vacume on the drivers front of the carb.
Old Apr 17, 2023 | 07:51 AM
You can easily test advance can function with a hand vacuum pump. Note that rust can lead to the point plate sticking.
dkraus71cutlass
Apr 17, 2016 06:49 PM
oldsmoguy
Dec 5, 2013 07:20 AM
84oldsDelta88
Mar 15, 2012 09:29 AM
Redog
Sep 20, 2011 03:58 PM
Pghstarsky
Apr 4, 2008 07:19 PM
