What fan and clutch should I get to cool my 403 build in my 66
Old Apr 17, 2023 | 10:51 PM
gearheads78's Avatar
car guy
My car still has the stock 4 blade and no shroud. It's always wanted to get warm on a hot day in traffic. I was thinking about going to electric but I don't really have the time modify the harness and upgrade alternator right now. I'm pushing as it is to build a motor in a few days. I think at least for now I'll just add a shroud and go to a fan and clutch. I'm going with a Summit universal shroud, so I have some flexibility on diameter. Haden has several part numbers they say will work as a replacement, but tech assistance would not give me a fan recommendation other than they are designed for an oem fan. If I go heavy duty or severe duty they say it must be used with at least 2.5" pitch fan. The Aftermarket Derale fans I'm finding say 2" or don't give specs other than diameter.
Old Apr 18, 2023 | 06:58 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Richard the only advice I can give is something you probably already know and that is the fan should be half in and half out of fhe shroud.
Old Apr 18, 2023 | 10:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I assume they are 6 or 7 blade fans? Go with the heavy/severe duty clutch as you mentioned. As said, make sure the depth is right in the shroud. Also use a closed impeller water pump and high flow thermostat with biggest large two core aluminum rad you can fit.
JPinAZ
May 12, 2022 04:45 PM
72GoldOlds350
Apr 25, 2020 12:59 AM
rothlane'68
Jun 27, 2017 09:46 AM
midrange
Apr 22, 2014 02:02 PM
Al Graaf
Apr 23, 2012 09:07 PM
