Clutch fan?
Hi folks,
Have had a flex fan/spacer on the 442 since i got it.
Looking at ditching it and converting back to a clutch fan.
Looking at part numbers from summit:
clutch: https://www.summitracing.com/parts/flx-5555
fan: https://www.summitracing.com/parts/flx-5719
I've read all over the forum that this is a good move, but three pretty lame questions for anyone with experience with this before I order parts:
-I am using a fan shroud from fusick that is correct for 69-72 (but fits for 68's, which is what the car is). CSM indicates a 19 inch fan for a 68. Will this fit my current shroud?
-The fan I am looking at states that it is 19 and 1/4 inches, will the additional 1/4 inch be a problem?
-Any issues I should be on the lookout for while making the swap/any reason to consider different parts? These seem to be the priciest (not by much) and they say you get what you pay for!
I can't offer any advise as to the parts being correct, but I strongly recommend that you get rid of the flex fan. As a retired EMT, I have seen on a couple of times, where people would be severely injured when they would reach over the radiator, and a flex fan would come apart when they pushed the accelerator rod to increase engine speed for one reason or another. When flex fans age, the flexing of the blade causes metal fatigue, and eventually it will break. Most times when this happens, there is no injury, because the hood is down.
I've read they become prone to "grenadeing" as they age. Mine is definitely getting up there and I'm not trying to see what that looks like!
I appreciate the offer, let me do a bit more research and I'll let you know.
I put a replacement clutch fan on both my Olds. You may find you will have to replace your motor mounts as the correct size fan will hit on the bottom of the shroud because they have fallen. That was what my experience was. I don't remember what # clutch I ordered but both work ok but are very noisy until they disengage. You can hear it driving the cars. Makes you think the car is still in 2nd and hasn't shifted. But they don't get hot when sitting idling as the 71 did with the old clutch.
While the hazards of the flex fans can exist, the problem with my '65 442 was that, after trying 4 or 5 different clutches (both thermostatic & centrifugal), I was unable to find one that would move much air at idle in the summer when it was needed most. Hence, to reduce the tendency of overheating, I was forced to use either a fixed or a flex fan.
I have always bought parts such as fan clutch from the local auto parts store. I don't really see a need to buy these common items from places like Summit, Jega, etc. when they can be purchased locally. It makes exchanges, warranty returns, etc much simpler.
Thanks for all the input, I'll let you know how it turns out.
I use the clutch from Ford pick up(V belt set up) really engage when the temp reaches 200 and will always be engaged at idle when it is needed most, I have a few that I have horded away and will never use.
Johnny
Johnny
The first dud was the GM version which came with the car; part number 387700 (2nd type 2-1/2" thick)
There were then two duds from NAPA. One was thermostatic; the other was centrifugal.
I had some hopes for the better ones from Hayden (the heavy duty thermal and the severe duty thermal) but they were not available for that application. Only the standard duty thermal could be had, probably due to available room.
I think that there was one more aftermarket thermostatic, but I can't remember the particulars. (Old age can be "rough" on the memory.)
The next move was to a 19" flex fan from Flex-A-Lite, part number 1309, which is currently still there (used with an appropriate spacer to get the correct placement). It does move considerably more air at idle, hence reducing the possibility of overheating. As I don't race the car, I thought that I'd "gamble" on the disintegration factor. So far, all remains intact.
On that car, the fan pursuit has been a "long road".
I also had to design and fabricate a home made shroud for it out of sheet metal, but that's a whole other topic.
Might have to give that a shot! do you know what year/model its from? I'll look into getting one if I have the same trouble Ozzie has had with his.
Bee Saint Louis
Apr 13, 2025 08:28 AM
