Factory choke mechanism bolt
Old Nov 25, 2022 | 03:33 PM
DDRock's Avatar
As title states my father has a 66 Olds Cutlass with the 330 4bbl Rochester. I just had the carb rebuilt and put it back on the car. He had a edelbrock on it. I was going to put the choke mechanism on the intake manifold but he lost the bolt. Any idea what size and pitch the bolt is? I have tried 1/4 inch 20 coarse but it only goes in about half turn. A 1/4 fine does not go in. Does not make any sense that it is metric??
Thanks,
Derek
Old Nov 25, 2022 | 04:09 PM
66-3X2 442's Avatar
Thanks,
Derek
1/4 x 20 ,chase the threads to fix any bad places.
Old Nov 25, 2022 | 05:54 PM
DDRock's Avatar
Ok thanks you sir. I’ll have to find one. I am in FL at my fathers and he does not have any thread chasers.
Derek
Old Nov 25, 2022 | 06:17 PM
66-3X2 442's Avatar
Derek
A tap will work also.
Old Nov 25, 2022 | 06:56 PM
DDRock's Avatar
He doesn’t have any either. I have a set in NJ. I’ll grab one tomorrow from a store down here.
Derek
Old Nov 25, 2022 | 07:04 PM
dbater's Avatar
Put a little never seize on the threads of the replacement bolt and run it in and out a couple of times.
Old Dec 2, 2022 | 09:43 PM
DDRock's Avatar
I forgot to update thread. It is 1/4 - 20. I sprayed some PB blaster into the threaded hole and let it sit for a couple of hours. New bolt went right in with no problem.
Thanks,
Derek
grannys442
Oct 14, 2021 06:03 PM
1967cutlassHT
Jul 25, 2021 01:52 PM
over my head
Jul 22, 2021 11:32 AM
oldsman7
Mar 25, 2011 10:08 AM
HouTXCutlass
Oct 4, 2010 11:54 AM
