SBO G Body downpipes?
Old Sep 3, 2023 | 03:20 PM
Shiftydr's Avatar
Does anyone make dual exhaust manifold downpipes that will fit a G Body with SBO? My car is a very original 1980 442. It still the original single cat exhaust with dual outlet muffler - way too quiet and restrictive. I will install the block off plate on the affected manifold.
Thank you,
Shiftydr
Old Sep 3, 2023 | 07:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Others have used the BBO Pypes down pipes with success.
Old Sep 4, 2023 | 09:02 AM
old80cs's Avatar
I used the Pypes 2.5” stainless downpipes and they fit fine. I did dimple the driver side to give a little more clearance to the control arm attachment bracket, other than that that fit fine. I read on another board that the exhaust manifolds from big to small block Olds are different but the downpipes are the same from one to the other.
Old Sep 4, 2023 | 11:23 AM
Shiftydr's Avatar
Headpipes
Thank you gentlemen! I have heard that the Pypes downpipes might work, but I wanted more information before shelling out the $180.00 on a chance. I already have a double hump cross member and Dynomax header back exhaust with Cherry Bomb Salute mufflers. The Dynomax pipes are only 2.25”, so I’ll have to weld in reducers. I’ll try to record a before and after for posterity. I think that should help wake up the otherwise stock, original, Olds 350.
Old Sep 5, 2023 | 06:03 AM
It will make a very noticeable difference. A guy with the 85 442 gained over a second in the 1/4 mile by just adding dual exhaust. The 307 HO cat back dual exhaust was definitely better than 80 442 exhaust.
Old Sep 6, 2023 | 02:21 PM
rogue_ryder's Avatar
G-Body Driver
These will work:
https://www.pypesexhaust.com/product...-2-bolt-dof10s
The fit isn't the best you might need to do some clearancing (smash with a hammer) to get around the starter on the driver's side. I reclocked my mini-starter out of the way, but a stock starter could be a little too close. I don't like how low the system hangs; IMO it needs to have some tubing cut out and re welded to tuck the exhaust closer to the car. It's not unacceptably low but a little too low for my taste (my car is lowered so YMMV).
I have them on my car (85 442) with this system:
https://www.pypesexhaust.com/product...-exit-includes
Bill Tupper
Apr 10, 2015 08:24 AM
wolfman98
Oct 27, 2009 07:37 AM
Delance318
Jun 15, 2009 10:19 AM
KQQLCAT
Apr 1, 2009 05:34 AM
tarheeldoc
Aug 27, 2008 11:51 AM
