Dipstick tube w Thornton manifolds
Old Jul 17, 2023 | 06:51 PM
deltsanddueces's Avatar
Anybody have problems fitting their dipstick tube when running the thorton 350 exhaust manifolds? I swapped a 307 for a 72 350 in my 84 98 coupe and I had a chrome dipstick tube but it barely fit thru the hole in the manifold which was causing an exhaust leak so I pulled it out and grabbed the dipstick tube from the 307 and put it in and it fit thru the hole better but I had to bend it kinda crazy and now the dipstick won’t make the bend. Can I take a die grinder and grind the not on the manifold out a little bigger to better fit the dipstick tube
Old Jul 18, 2023 | 04:57 AM
CANADIANOLDS's Avatar
Even if using gaskets..you gotta grind clearance for it.
Denn’s64
Jan 25, 2023 04:08 AM
yalikeme
Aug 29, 2015 11:51 AM
Charles Ludwick
Jan 27, 2012 06:59 PM
billykissell
May 16, 2011 05:58 PM
defiant1
Apr 30, 2011 08:41 AM
