Rookie alert
Old Apr 8, 2023 | 09:31 AM
billbane@live.com's Avatar
Rookie alert
Rookie Alert
So I picked up a 70Holiday Cutlass S. Try to determine the engine match or not . Here are the numbers off the block
Block #395558 2
Heads 403 858
Heads # 6
Block# 30M412997
Oil fill 0633612
Any help would be great
Old Apr 8, 2023 | 09:37 AM
I moved your post to it's own thread in lieu of resurrecting an unrelated one that's 8 years old. Post your vin#
Old Apr 8, 2023 | 09:38 AM
Welcome. We look forward to seeing pics of your Oldsmobile.
Old Apr 8, 2023 | 09:50 AM
It’s the correct era block and heads. There is a partial VIN stamp on a pad just below the #1 cylinder that will match the vehicle the engine was in from the factory.
Old Apr 8, 2023 | 09:56 AM
Originally Posted by billbane@live.com
Rookie Alert
Block #395558 2
Heads 403 858
Heads # 6
Block# 30M412997
Oil fill 0633612
Since you didn't provide the VIN, there is no way to know if the VIN derivative on the block matches or not. In any case, the number on the oil fill tube is the engine unit number. The first digit is the model year (0=1970) and the rest is just the sequential build number of the engine. The first character of the VIN derivative stamp on the block (and trans case) should match the first character of the car's VIN (in this case, "3" = Oldsmobile division).
The last eight characters of the VIN derivative will match the last eight of the VIN.
Old Apr 8, 2023 | 11:12 AM
As per information already provided, here are images of my VIN plate & its matching VIN derivative stamp (1971 Oldsmobile Cutlass Supreme)...
Block VIN derivative
Dash panel VIN plate
Driver door VIN decal (if yours happens to be there)
Moegs
Oct 15, 2022 08:36 PM
Phoenix8990
Oct 28, 2020 12:12 PM
sortasane
Jun 8, 2016 03:06 PM
Grinder
Dec 24, 2010 05:46 AM
ZASX
Mar 11, 2008 10:44 AM
