1971 Cutlass 350 Mufflers
Old Mar 4, 2023 | 08:53 AM
Falkon's Avatar
I once had a Mark VII where I drilled a 1/4" hole at the bottom rear of each muffler to try & avoid premature rusting. It seemed to work OK. A lot of water dripped out before it worked its way to the tail pipe. I'm wondering if such an idea would work w/ the cutlass, since the chrome exhaust extensions (not factory) get residue on the bottom from water & carbon blowing out. Does this sound totally wrong, or would it matter? The car is loud enough, so it wouldn't increase sound. Just wondering.
Old Mar 4, 2023 | 09:44 AM
It used to be most mufflers had a weep hole to drain condensate.
Old Mar 4, 2023 | 09:50 AM
Sugar Bear's Avatar
Probably work but 1/4" may be larger than needed. I'd try 1/8 - 3/16.
Old Mar 4, 2023 | 11:04 AM
^^x2^^
Old Mar 4, 2023 | 11:43 AM
Falkon's Avatar
The car has Flowmaster mufflers, w/ no holes. I'll try 1/8". Thank You, Al
harpelt
May 31, 2020 08:50 PM
rmoths
Jul 9, 2014 03:26 PM
805cut
Jun 8, 2012 03:15 PM
1965cutlassragtop
Jul 13, 2011 06:48 AM
Oldtimer1969
Apr 29, 2011 02:20 AM
