I was doing my timing chain. Found the key in the crank keyway is round? To my knowledge engine has never been apart. Still has original gm nylon gears. Is a round key the factory key? Should I replace it? Its a 2 barrel car, it does not have a harmonic balancer. It uses a pulley. 1964 crank hub
I do not think that is correct even for a 67 two barrel motor. All 67 two barrel motors did not have a balancer but had a hub that was counterweighted and the pulleys bolted to that, used the typical 1/4 square key.
It's been apart. That is NOT a factory installation. Someone lost the original key and stuffed in that piece of round stock. Looks like your timing marks are off by about 5 degrees as a result.
Its a pulley and hub, this car has no true harmonic balancer since its a 2 barrel engine. I will replace with square key. It still has the original timing gear stamped "GM". Looks like only 1 or 2 nylon teeth broke. Its a lower mileage car. Thanks for the advice....
I reminded of the old square peg in round hole adage. In this case a round peg in a square hole. Since you are already doing the timing chain this is an easy fix and should be corrected.
