69 Cutlass S 350 vacuum line question
Old Oct 21, 2022 | 05:16 PM
lala5818's Avatar
I have a 69 Cutlass S convertible with the original 350. The power brakes and transmission have dedicated vacuum lines. I have an MSD electronic distributer (not vacuum assisted). I'm trying to run the vacuum line for my trunk release and need to know if I can run a dedicated line off the intake or do I need one of those canisters?
Thank you
Old Oct 21, 2022 | 06:19 PM
You want the canister so the remote trunk release works after the engine is turned off. The canister pumps down while the engine is running and has a check valve so it retains vacuum to operate the trunk even with the engine off.
Old Oct 22, 2022 | 04:53 AM
lala5818's Avatar
thank you Joe.
I have two copies of the assembly manual and the print quality is poor on both. Do you have a readable vacuum line routing diagram?
Puppy boy
Sep 20, 2021 05:32 AM
Racecarguy1968
Feb 17, 2020 06:54 AM
Homestar
Apr 3, 2011 05:54 PM
cutlass cool
Oct 8, 2008 10:22 AM
54olds
Aug 7, 2008 12:20 AM
