403 to 350
403 to 350
Guess I should have looked around the small block area before posting so sorry and I'll just keep looking for another 350 block to find another 350 crank.
I think you’ll find that all the small blocks of the era shared the same stroke (3.385”) and journal diameters. I would think the balance would be different on a 403 but that is something I don’t know. Wait for others to reply.
Every small block Olds motor made from 1964-1990 used the same 3.385" stroke. All gas small block cranks interchange. Obviously the balance may need to be corrected if, say, you try to use a 403 or 307 crank in a 350, but they will physically work.
