69 Cutlass 350 trunk vacuum question
Old Nov 9, 2022 | 06:00 AM
lala5818's Avatar
I have a 69 Cutlass with the original 350. It has an Edelbrock performer 4BBL intake on it.
I'm running the vacuum line for my trunk release. Can put a tee in the vacuum that runs the power brakes or do I need to put in a dedicated line?
If I need to run a dedicated line, I'm having trouble finding a vacuum port that will fit my Edelbrock intake. Where can I find one?
Old Nov 9, 2022 | 07:13 AM
The trunk operates from manifold vacuum. Any port that ties directly to an intake runner is fine. The hose for the power brakes is also fine. Don't lose a lot of sleep over this. Also, you do need a vacuum ball with a check valve between the manifold port and the trunk to ensure this system works with the engine off.
Old Nov 9, 2022 | 07:38 AM
Bfg's Avatar
Bfg
Is there a check valve on a 65 Cutlass with vacuum trunk release, it seems like the trunk will open one time or while the car is running
Old Nov 9, 2022 | 07:48 AM
Yeah, the vacuum canister is sized for one or two operations of the system without the engine running. As the rubber parts age, the system can leak down sooner than anticipated. Once that vacuum is depleted, the engine needs to be started again to re-evacute the system. If there were no check valve, the system wouldn't operate at all with the engine off.
Old Nov 9, 2022 | 07:53 AM
Bfg's Avatar
Bfg
I guess I forgot about the canister on the firewall. Now it makes sense
lala5818
Oct 22, 2022 04:53 AM
Koda
Jul 13, 2020 01:11 PM
ej69
Apr 26, 2018 08:03 AM
Bfg
Oct 26, 2015 01:56 PM
PmL69
Aug 22, 2009 05:39 PM
