missing vacuum hose
Old Apr 25, 2018 | 07:35 PM
ej69's Avatar
missing vacuum hose
1969 cutlass s convert, v8/4bbl w/ a/c, pb
going over the engine, i notice, what i assume is a vaccum can, on the driver side tucked under fender by firewall. There is a vacuum line going off can an into firewall to under the dash. The other port on the can has nothing going to it. I assume a vacuum line from the engine goes to it. what is this for. I have looked in my manual and it appears something to do with heating/cooling?
thanks.
Old Apr 25, 2018 | 07:37 PM
tru-blue 442's Avatar
Old School Olds
Do you have a trunk release button in the glove box?
Old Apr 25, 2018 | 07:47 PM
ej69's Avatar
i do, it doesnt work and ive never really looked into it. i figured it was electric operated.
thanks
Old Apr 26, 2018 | 07:28 AM
The A/C flapper doors under the dash are vacuum actuated. There is a vacuum can on the firewall to act as a reservoir for this system. Normally, there is sufficient manifold vacuum to operate these actuators, but if you step on the gas, manifold vacuum drops briefly. The reservoir serves to maintain the function of the vacuum actuators during this period of low manifold vacuum. If the can is not connected, you may just not have noticed the temporary drop-out of vacuum under acceleration.
If you have a vacuum trunk release, there would have been a separate vacuum canister for that system. That canister is intended to retain vacuum to allow you to operate the trunk release after the engine is turned off.
Old Apr 26, 2018 | 08:03 AM
mrolds69's Avatar
It is for the trunk release, that's where my can is. It needs to be tee'ed into the main vacuum to work.
jdana24
Jun 22, 2017 09:26 PM
Robert Zuijdam
May 11, 2016 06:42 AM
Sampson
Mar 24, 2015 09:33 AM
jrbarrie83
Jul 9, 2006 09:26 AM
daddyjws
Dec 21, 2003 04:04 AM
