Heater Hose Tension Spring Hose Clamp (Corbin Style)
Old Jun 22, 2017 | 09:01 PM
jdana24's Avatar
1968 Olds Cutlass S
Can you reuse the heater hose 3/4" tension spring clamp? The engine only has about 200 miles on it since the rebuild and the new hose and clamp were put on, but I need to remove the hose briefly and then put it back on, and want to know if it is OK to reuse the spring clamp without worrying about it leaking. Would it help to use Permatex #2 Non-Hardening Form-A-Gasket Sealant? Attached is a photo of the clamps.
Old Jun 22, 2017 | 09:26 PM
The only way you'll know if the clamps work is to try them. I always carried a couple of worm clamps just in case. Don't use sealant.
72cutlass408
Jul 16, 2019 08:07 AM
68442
Aug 10, 2016 03:50 PM
1yesfan
Oct 7, 2014 06:43 AM
my71olds
Apr 28, 2013 06:08 PM
Del70
Jul 2, 2012 08:35 AM
