View Full Version : Big Blocks
- Tri carb gaskets
- Intake Manifold Gasket 400c.i. Motor
- 64 394
- New guy with a 425 question…
- This misfire is defeating me. please help
- How to Identify Distributor
- Oil for my '66 425
- Power Decrease
- Better oil ddistbution
- Olds 350 Diesel Oil Pan Gasket
- Carburetor questions...
- Fuel Pumps
- Recommendation for Cam Shaft & Lifters
- Olds 455 compression issues
- Exhaust Manifolds-66 442
- Oil coming out of exhaust
- Fan clutch diagnosis
- Lifter noise - dead cylinder then ok
- Correct engine color 1969 442
- 1972 Cutlass Supreme 455cu engine with Ga Heads
- Too much?
- Expansion Tank Ideas?
- 455 Head Gaskets
- valve springs
- HEI advance
- New piston
- Oil pressure sensor light on.
- 1972 455 engine rotation?
- rear main seal
- Mid throttle surging, missing issue
- Newbie question on bore size
- Aftermarket A/C 66-442
- Exhaust Manifold Bolts
- Cartech books
- Engine Stamp 1971 455
- Idle problem
- 455 timing question..
- What are One F head and Forged 455 Crank worth
- 67 Olds 442 runs rough in idle when put in Drive with foot on pedal
- C Heads What are they worth?
- Why are J heads so bad?
- Edelbrock 7551 Air Gap Intake Manifold/Edelbrock 8711 Carburetor Phenolic Spacer
- 1973 U code 455 with manual trans code carb
- 455 Long Tube Headers For Gbody
- Valve cover mounted wire harness clip
- 67 motor mounts
- Hairline cracks in aluminum W30 intake manifold
- 66 400 overbore
- Headers on. ‘72 455?
- Thermostat advice
- Which carb mounting gasket?
- Reseal intake manifold ???
- Scrap or Sell?
- What is this?
- After Market Manifold Gasket
- New Delta owner and new to the forum! First post!
- 303-324-371 Engine Question
- Correct plugs
- Steel 455 crank value
- Steel 455 crank identification
- Was naively hoping...
- Pulley spec please...
- Stock intake 455 water jacket???
- 67 425 motor rebuild
- Rocker bridge..
- 455 pulley help
- Timing chain craziness!!
- Q - Pilot Bearing BCA 7109
- 455 hole inblock
- Suggested Engine Rebuilder for a 67 442 400?
- 425 build questions
- Motor year
- Looking for big block ported head flow numbers.
- Speedmaster’s “single plane” dual plane intake
- Pulley help
- Cam decisions
- Christmas Intake cookies! Opinions?!
- flywheel bolts
- 72 455 no AC rear heater hose
- Which timing chain would you buy?
- distributor gear
- 455 ID engine
- Best place to have a quadrajet rebuilt
- Been sitting
- gathering parts for engine rebuild 425? or 455?
- Timing chain replacement
- pilot bearing
- Apology in Advance: '70 Toro 455 into '70 Cutlass Supreme
- 394 pistons
- ISO 0.001" Under Connecting Rod Bearings
- What fits under the hood
- Larger valves for c heads
- Modified valley pan
- 1970 455 carb question
- 1969 442 Engine
- EBay kits
- Big block 455 mpg
- 1966 Starfire 425: Electronic ignition upgrade (Pertronix)
- 64 394
- '66 V8 total timing
- 455 oil filler tube removal
- Motor mounts
- Exhaust crossover - how it works?
- 455 Timing Chain Set Wont Install in Any Position
- New pistons arrived with dings/scratches - fixable?
- Coolant line replacement
- 455 accessory bracket interchange
- 1966 400 knock
- Oil Leaking intake
- 455 harmonic balancer repair sleeve
- Finally!
- 394 Front Crank Seal
- Part ?
- What is correct quadrajet for my 75 H/O 455
- Lazy 425 Super Rocket engine
- Were all U codes the same for 1972?
- Camshaft for 425 in 73 Cutlass Supreme
- Dipstick wont fit?
- Head torque specs
- Old OEM intake & exhaust manifolds
- Springs on 455 4bl? Correct or not
- What to do if classic Oldsmobile is partially or or submerged in fresh or saltwater
- 455 "c" head,now a "boat anchor"?
- H 455 heads
- Random top end knock
- Exhaust crossover 66 Toro 425
- 66 toro engine
- Dipstick tube removal
- Upper Hose on 455 collapses at cool down
- 66 Toronado engine help please
- Cyl head number pad
- 394 Gasket Kit
- 455 oil modification tips?
- Help Identifying My Oldsmobile 455 Rocket Engine
- Coolant
- Change distributor and others 1791 Oldsmobile 442
- Digital Tach hook up to distributor 75 H/O
- Coolant hose size
- Carb bolts....
- Head gasket?
- Help with 455 project
- 1969 Olds 442 knock
- Radiator Hoses: 1966 Olds Napa Part Numbers
- Speedmaster Valve Spring Replacements
- 1967 425 Oil Dipsstick Tube O-ring or not?
- Exhaust manifold leak
- 71 455 4-speed vacuum lines and distributor vacuum control switch
- Vacuum Advance Adjustment
- New connecting rods, pistons, rings, etc.? or use old connecting rods?
- 67 442 exhaust manifold info
- Another 455 build started with Mark
- Intermittent stumble and miss
- Dwell, detonation, and being dumbfounded
- 394 With No oil to Valvetrain
- 1965 425 Engine rebuild time!
- Kindly Confirm 7 blade radiator fan installation - which side is front?
- Thermostat fun: Opening Temp Variance - measured
- Heater core hose clamps
- 1964 Oldsmobile external transmission cooler??
- Aluminum Engine ID assistance request
- 75 Hurst Olds w/455
- Catch or Release?
- Low cylinder - '66 425
- 425 or 455
- Cam Reccomendations
- Bad thermostat?
- 455 Water Pump Advice
- 72 cam ?
- Looking for engine rebuilding suggestions
- 1971 442 oldsmobile - Timing and cylinder 1
- 455 torque upgrade ?
- 1971 455 Rebuild for Delta 88 convertible
- Fuel Pump Rebuild
- 394 intake ?
- '75 455 Bad Timing Chain / Gear?
- Dieseling fixes
- Make a 1965-1966 big car shroud from a 1966 Cutlass shroud for better cooling
- PCV and EFI
- Low Compression 455
- Correct passenger manifold for '72 98 with 455
- 455 to 496 - Kit vs Recipe
- 1967 400 .921 lifters
- 69 Choke Thermostat
- 68 Cutlass 455 head bolt stud replacement.
- 1971 442 - Engine temperature
- 67 400 Olds .921 Lifter please help
- Starter kickback at startup?
- Motor mount problem
- 1959 371 cooling system
- Upgrading Rocker Stud Threads - 455 Iron Heads
- Roller Lifter Interchangability
- Carb fuel issues??
- Torque 371 1960
- 400 Eng Oil Plugs
- Speed master shaft mount rocker arms
- Start-up Question
- Olds 455 non-resistor "cold" spark plug, iron heads
- My 1971 455
- Refresh roadblock
- Cam and Intake recommendations
- 1970 Delta 88 455 4 barrel - thoughts on engine swap
- head gasket sealer
- Fuel pump,to filter, to carb line
- 64 394
- Correct Ignition Distributor Bushings for an Olds 400E?
- Trying to identify an engine block
- 61 Olds 98 mechanical fuel pump oil leak
- 1968-1970 Coolant Recovery Tank
- Question about a set of Ka heads.
- Trying to identify this engine....
- '68 Olds 88 Oil Pressure Light flickers even when full of oil
- 455 water pump
- Used cam, new lifters
- 1970 98 Timing Advance
- Logical explanation or wishful thinking?
- Fuel and starting problem with 1967 Oldsmobile 98 Luxury Sedan 425 engine
- 455 cam question
- 1970 442 455 Cam suggestion - Stock good enough?
- Thank you all so much.
- Diesel oils
- Help with 1966 Olds 442 L69
- Boring a 455 block for a sleeve
- Where can I get this breather part?
- ‘70-‘72 OAI Drain Hose
- '73 455
- Smog pump delete
- Toronado 455 to 425
- External balance flex plate
- Set Initial Timing
- Air filter options 455 1970 A-bod
- Engine Stumble
- Valve cover grommet
- A really basic question about oil
- Torker intake question.
- Power steering pump part #
- 425 Rebuild
- PCV Pulling Oil Vapors
- Valve spring installed height
- Mounting a 1970 455 Exhaust Manifold Shroud
- Bowl porting/smoothing into hardened seats
- Tuneup talk
- Fuel pump fittings to pump tape or goop?
- Curious as to how many or if anyone is running a Holley 6212 on a 455?
- 1961 Ninety Eight Rochester 4 barrel rebuild
- Internally balanced 455….Is it feasible
- Dirty oil and crud??
- Distributor test specs - help
- Air Cleaner on a 1970 455
- Throttle cable bracket for Holley 4150
- heater hoses routing 455 no A/C
