- Corteco 55661 .028" Head Gaskets
- Old school M/T valve covers. Need a breather that fits
- 371/394 4 bbl intake: '59 D88 2 Dr
- New 461 need some advice
- 65 Cutlass 455 Exhaust Manifolds? W & Z?
- 1968 455 factory hp?
- horrid engine vibration
- Need 69 400 STD Piston
- Hardened Valve seat
- 455 Oil Fill Tube
- degree wheel
- 495 Stroker BB
- timing
- performer 2151 intake and OEM Q-Jet | Throttle bracket question
- No compression
- Heater Box - Should I leave alone?
- 394 or 371?
- Won't go fast
- 67 442 boiling over
- Does your VIN end in 178412? 69 442, I have your engine
- need headers for a 455 for 1968
- oldsmobile c heads
- Heater control valve placement
- 403 engine build
- Vacuum lines on 67 Cutlass 442
- OAI Air Cleaner Vacuum Hose Questions
- cam selection
- spark plugs
- Intake leak?
- Stroker kit and G block - eagle recomendations
- Poly motor mounts
- 1968 400 442 Pistons
- timing and vacuum test
- Cast ring gap
- cam selection
- 455 1971 Connection Rod Question
- I Picked Up The Lowest Mileage 455 In History, I Have Questions.
- Flywheel inspection cover
- How to test ignition voltage
- 495 BB Stroker/Spark Plug/Air filter test
- 69 442 400cu in Timing.
- Machine shop in New Jersey
- a good timing vid or write up?
- H Head Spring Etc...Recommendations
- Rotators 71 G head
- Opinion help ..455crankshaft,425 rods, Pontiac pistons
- How to tell if car is 455 or not
- Fuel tank sump
- Engine mount height
- Piston ID and tight rods
- Will a 1969 442 400/ 4 speed bolt into 1970 with a 455/3 speed?
- 10w30 or 20w50?
- Valve train noise.
- olds 455 won't start
- spark plug thoughts and anything else a new owner should know
- Distributor vacuum control switch/valve
- Am I asking for trouble?
- Accessory brackets
- Too much oil in head?
- Where to source new cam button and spring
- Couple of 455 block questions
- Edelbrock 2151 Performer Intake Coolant Line
- 1965 425 OLDS rocker arms ?
- Question about headers
- KB277 bore size
- Too much cam not enough compression
- Dmr new style valley pan and roller lifters
- intake gasket
- 1971 - 455 Crankshaft
- Oiling question
- 455 Factory “high-compression” pistons
- Valve Cover Question
- 455 thoughts
- Does anyone (besides me) paint their engine BEFORE assembly?
- Question about W30 exhaust manifold...
- Oil Fill Tube Numbers?
- 72 delta 88 455 vacuum line diagram
- Engine decode ?
- Blown 455
- Broken Choke Stove Bolts
- Spark plug question..
- 425 Toronado Timing Cover Removal Help Please
- Part Number For 71 W30 Fuel Pump Needed
- 69 delta 455
- Correct throttle cable grommet?
- Cutlass with toro oil pan
- 455 Engine Rebuild
- 425 Harmonic Balancer Help Please
- Choosing a Carb
- Red line
- 455 G Head Valveguide
- Head bolt stud locations for 69 442
- Hose clamps
- W-30 Intake Restoration
- 70 455 motor
- Custom roller cam
- piston to wall clearance
- Piston Clearance Help
- c heads
- Tall valve covers with A/C
- Weird place for an oil leak
- removing draft tube on my 57 371
- oldsmobile 394 vaccum nippe under intake
- 1970 w-34 questions
- oil pump drive shaft
- Seeking Carburetor selection advice
- help with roller rocker install
- 442 Bronze Paint Torture
- GM B body exhaust interchange?
- Exhaust flange gasket won't seal
- Compression
- Timing cover 371
- Omega motor mounts
- Roller cam recommendation
- Crossover plugs or not
- Air cleaner base drainage holes with OAI
- "B" castings with AIR ports
- Thinking of selling 394
- Should they stay or should they go?
- Headers for a 72 Cutlass Supreme
- Water in cylinder after intake swap
- Grooved main journal 455
- Identifying forged internals from the oil drain hole
- Not getting oil to the rocker arms
- Erson TQ40
- 455 4spd crankshafts
- difference between 455 396021f and Fa
- ka heads
- Winter Restless
- Engine code decal info needed..
- Distributor rebuild
- Lost my timing crank sprocket key for my 76 455 olds engine.
- Just wondering...
- 455 build
- olds 394
- 455 id
- water in cylinder
- 1970 455 ??
- J heads
- Engine
- Pushrod length
- 1968 H/O Temperature Sending Unit Location
- Throttle cable
- 394 ident.
- Do Edelbrock heads allow mechanical fuel pump retention?
- Oil fill tube or lack of
- Need advice on 455 build!
- New Oldsmobile Owner...
- 70 442 Iron Intake, 4 Speed or Auto? Any advantages?
- what is this on my piston rod?
- 67 400 in a 68 442
- Starting issues...
- Knocking after radiator flush
- Fresh Rebuild 67 442 PCV Sucking Oil
- 371 heads on a 394?
- comp cams roller tip rockers
- Pulley alignment
- Project Torque Monster
- 71 4 Speed Carburetor ?
- 71 W30 Engine Build
- Rough Idle Question
- Vacuum Tank on Firewall
- Value of original engine size vs swap
- Swapping in old motor
- 1969 455 Noise w/ video.
- Distributor Question
- Mechanical Fuel pump question
- 1965 425" feels like misfiring
- Carb restoration
- Milling heads
- Repurposing freshly built 455
- Suto Choke
- Bracket Ported C Heads
- Building 455 motor
- BBO tried tricks
- No Compression On Fresh Rebuild 400 E Block
- GM Distributor Point Adjusting Tool, Where to buy?
- Fan Hitting Shroud
- 1970 455 assembly detail
- What's needed to switch to hydraulic roller cam
- Stock cam timing question
- Oil filter adapter question...
- Normal oil pressure?
- 371 engine
- 1984 Delta 88 307 & thm200 to 455 & thm400
- 67 Olds 442 Oil Pan
- ’68 442 Tach Install
- 371 Exhaust Manifold
- Engine rattling under acceleration
- Price check 455 block
- Connecting Rod Bearing Size
- Cooling hoses
- Raising compression on a 455
- 1965 Jetstar 1 carb swap
- Block and crank
- Exhaust manifold opinion
- 350 to 455
- 455 Oil pan gasket
- Adjustable rocker conversion
- Vacuum Advance or not?
- Quadrajet hot start question
- Olds 425 dementions
- Oil capacity question...
- Question for the Oldsmobile gurus part two...
- Question for the Oldsmobile gurus..
- O-ring block head gasket replacement
- Its a Mystery.......
- 455 cam
- Plugs ?
- Fuel line help/guidance
- Could use some knowledge please
- "GA" heads...
- Original octane requirement
- C heads worth putting money into
- Break in Oil ? Or not ?
- Can't get pulleys to line up???
- 425 differences
- Oil Pan ?
- I need help on head if numbers
- 72 olds cutlass
- Olds 455 ring gap question
- Head intake port dimensions
- Tuning Suggestions
- 425 Question
- Performer Intake ports - what goes where?
- Pilot bearing?
- Off Idle Hesitation
- Engine ID
- Carb Question for a 495
- 1972 455 donut gasket
- Intake manifold bolts
- FlowKooler Hi-Flow Mechanical Water Pumps 1775
- narrower oil filter housing
- Update 455,turbo?,supercharger?
- 394 valve covers on a 455??
- Radiator recore in Pacific Northwest?
- BIG LONG oil filter?
- Exhaust
- Fuel pump leaking oil..lots of it!
- 455-350 ?
- Blocking water pump to heater core
- 455 Olds broken water pump impeller
- 455 harmic balancer bolt
- Cam Lube for break in - hydraulic flat tappet
- Need pics of power steering bracket clearance to steering box on 66-67 Cutlass
- 394 tear down
- Help! needed for ignition settings
- Engine numbers
- 463 EFI Build
- Olds 425 pinging with more than 26° total timing
