OAI Air Cleaner Vacuum Hose Questions
Old Apr 8, 2019 | 06:36 AM
Tjohn8573's Avatar
I purchased a OAI Air Cleaner for my 1968. I’m have questions on how the vacuum lines hook up and was hoping someone could help. Wee both flapper hooked up? If so, was a tee used to hook them both up? Wondering how all the vacuum lines should be correctly hooked up.
Thanks Tim
Old Apr 8, 2019 | 08:17 AM
Hairy Olds's Avatar
Shoveling Snow
I can sell you the whole PIM if you would like.
Old Apr 8, 2019 | 08:45 AM
Tjohn8573's Avatar
Thank you for reply and very clear picture of the page out out of the PIM. I do have a copy of the PIM but it does not clearly show how all off the vacuum lines are hooked up or if both side flappers are even hooked up. Amd if they are both hooked up what is the proper way to route them.
Old Apr 8, 2019 | 12:22 PM
Hairy Olds's Avatar
Shoveling Snow
And the PIM wouldn't have that info. The air cleaner came from the supplier already plumbed with the vac hose.
Tjohn8573
Nov 28, 2018 02:18 PM
mmbuffny
Aug 9, 2013 02:23 PM
Jimoldsfan
Mar 2, 2013 11:47 AM
droptopcad
Oct 24, 2010 04:44 PM
442oldslawyer
May 16, 2010 07:15 PM
