OAI Air Cleaner Vacuum Hose Questions
Old April 8th, 2019, 06:36 AM
Tjohn8573's Avatar
I purchased a OAI Air Cleaner for my 1968. I’m have questions on how the vacuum lines hook up and was hoping someone could help. Wee both flapper hooked up? If so, was a tee used to hook them both up? Wondering how all the vacuum lines should be correctly hooked up.
Thanks Tim
Tjohn8573 is offline
Old April 8th, 2019, 08:17 AM
Shoveling Snow
Hairy Olds's Avatar
I can sell you the whole PIM if you would like.
Hairy Olds is online now
Old April 8th, 2019, 08:45 AM
Tjohn8573's Avatar
Thank you for reply and very clear picture of the page out out of the PIM. I do have a copy of the PIM but it does not clearly show how all off the vacuum lines are hooked up or if both side flappers are even hooked up. Amd if they are both hooked up what is the proper way to route them.
Old April 8th, 2019, 12:22 PM
Shoveling Snow
Hairy Olds's Avatar
And the PIM wouldn't have that info. The air cleaner came from the supplier already plumbed with the vac hose.
Tjohn8573
November 28th, 2018 02:18 PM
mmbuffny
August 9th, 2013 02:23 PM
Jimoldsfan
March 2nd, 2013 11:47 AM
droptopcad
October 24th, 2010 04:44 PM
442oldslawyer
May 16th, 2010 07:15 PM
Quick Reply: OAI Air Cleaner Vacuum Hose Questions
