Blocking water pump to heater core
Old Jul 13, 2018 | 09:13 PM
louie's Avatar
Can you block the out from the pump and rear of the intake or just run a hose between them ? Going to start a engine on a run stand Car probably won't have a heater also.
Old Jul 14, 2018 | 03:30 AM
You can do it either way.
Old Jul 14, 2018 | 05:50 AM
Factory heater delete cars simply blocked the ports. There is no need to run a hose. Consider that there is no hose going to the rear driver side anyway, so what makes the passenger side different?
Old Jul 16, 2018 | 07:08 AM
oddball's Avatar
For a quick job you can just throw rubber caps on them. Every rubber cap I've used in the past few years has failed within a few months, so keep an eye on them.
Next time you have the water pump off the nipple can be tapped for a plug and you can replace the heater control valve with a plug.
Old Jun 23, 2020 | 01:36 PM
Orlando 1's Avatar
O'smobile
Anyone have a factory heater delete pics?
Old Jun 23, 2020 | 01:38 PM
Of what? The extra port on the water pump got a rubber cap with a wire spring hose clamp. The nipple at the back of the intake was replaced with a pipe plug.
Old Jun 23, 2020 | 01:44 PM
Orlando 1's Avatar
O'smobile
This supposed to be super rare 67 442 at David's Classic Cars. He has the temporary same rubber blockoff everyone gets with a rebuilt pump.
http://davidsclassiccars.com/oldsmob...rack-pack.html
Someone out there must have a 'real' heater delete car and pics of the fittings.
Old Jun 23, 2020 | 01:47 PM
That's exactly what the factory shows in the Assembly Manual drawings. Whether that particular car is real or not I cannot say, but the cap is correct, as is the wire spring clamp.
Old Jun 26, 2020 | 03:04 PM
Orlando 1's Avatar
O'smobile
So, anyone out there have a heater delete? Share your photos showing the block off locations please. I love this community and the sharing of information about the way these cars were made. Thank you to everyone who makes the effort to connect and learn from each other, you make this a great place.
tim.f.wallace@sbcglobal.n
Jun 27, 2020 10:55 AM
rktolds
May 13, 2014 08:43 PM
RetroRanger
Aug 20, 2013 11:51 AM
70Cutlass_408
Jul 30, 2011 02:50 PM
Kidcutty
Jun 17, 2010 07:48 PM
