65 Cutlass 455 Exhaust Manifolds? W & Z?
Old May 6, 2019 | 10:50 AM
jmos4's Avatar
Hi all,
Gathering parts to do a swap and see 2 different sets of repro manifolds list for 64-67 or the W & Z 68-72. Will either work in a 65 and is one better flow wise?
Regards,
Old May 6, 2019 | 11:07 AM
Originally Posted by jmos4
Hi all,
Regards,
Either set will work. The W/Z manifolds are internally divided and flow better. The outlets may not match up with repro 1965 exhaust pipes, however. If you are using a custom fitted set of pipes, then this is not an issue.
Zr1bandit
Mar 2, 2017 05:34 AM
stonecad
May 19, 2015 09:27 AM
olds4life
Aug 12, 2010 07:34 AM
citcapp
Nov 26, 2007 07:54 AM
