Cast ring gap
Old Apr 4, 2019 | 10:20 AM
Jhucks03's Avatar
Cast ring gap
Cast rings, stock pistons. What ring gap would you run?
Old Apr 4, 2019 | 12:54 PM
don71's Avatar
same but different
Until someone can give you some Olds specific numbers here is what Hastings has to say about it....
https://www.hastingspistonrings.com/...sion-ring-gaps
Old Apr 4, 2019 | 08:43 PM
Battenrunner's Avatar
What engine size and what will it be used for?
What pistons are you using? New or Used?
Did you measure the ring grooves for ring thickness, clearance, and for Radial thickness?
Race, street, cruising?
Are you having the block honed professionally with a torque plate or doing a Ball-hone?
The main idea is to make sure the second ring has at least .002+ wider gap than the top ring.
Also, are both top and second rings cast, or do you have a ductile iron top ring and a cast second ring.
Old Apr 5, 2019 | 05:40 AM
cutlassefi's Avatar
.0045 per inch on the top ring and .0055 per inch of bore on the second for your application. In addition, make sure you have at least .015 on the oil rails. Ring material is irrelevant.
Cpriester123
Oct 14, 2016 07:26 AM
pogo69
May 19, 2014 01:50 PM
coppercutlass
Jun 15, 2012 08:42 PM
OLDSmobility
May 13, 2011 07:47 PM
dman0712
Apr 13, 2010 06:38 PM
