Old school M/T valve covers. Need a breather that fits
Old May 10, 2019 | 11:45 AM
VinMichael's Avatar
These valve covers have an odd “D” shape for the breather and PVC valve. Does anyone know of a breather that fits well? The one that I bought fits too loose.
Old May 10, 2019 | 01:10 PM
Schurkey's Avatar
Photo?
Old May 10, 2019 | 10:54 PM
Inline's Avatar
The opening on those M/T valve covers for breathers are actually D-shaped ( and from memory so is on stock valve covers), but the stock rubber grommet fits those great. Then you can mount your breathers.
Old May 11, 2019 | 09:06 AM
RetroRanger's Avatar
72 Olds CS
I think there are two sizes to the stock rubber grommets a larger and a smaller one. Maybe you just have the smaller one?
Old May 11, 2019 | 11:26 AM
cdrod's Avatar
Rodney
I have the M/T valve covers and I bought the grommets from RockAuto. The aluminum M/T covers are thicker than the stock, stamped steel, so I had to modify mine with a Dremel to get them to fit. FYI, the M/T covers do not usually have baffles inside, so you may have some oil in the PCV valve; also the grommet holes are not centered like the stock covers so if your running a stock air cleaner, the metal tube probably won't reach the valve cover.
Old May 11, 2019 | 11:42 AM
Inline's Avatar
Doesnt all of the M/T valve covers have spot for baffles? They are not huge, but baffles none the less. I have NOS ones, and even drawings from them. Attaches with self-screwings to two bosses cast underneath.
Old May 11, 2019 | 11:46 AM
70sgeek's Avatar
'72 Cutlass ragtop
They do have screw-in baffle plates - I have a set with the baffles intact.
you can probably make them from sheet metal if you had to and it would be a good idea to have them so you're not sucking large amounts of oil through your PCV.
Old Feb 8, 2023 | 06:44 PM
rogue_ryder's Avatar
G-Body Driver
Are you selling these Baffles? Do you know where I could source some? I have a set of these and I don't want oil getting sucked through my PCV or blowing out the breather. I've been scouring eBay and the internet looking for something that would work. Heck even if a template was available I think I could cut and bend up some 16 or 18 gauge sheetmetal.
I'm looking for the baffles that screw in just like this:
Any Help is greatly appreciated!
FTW65W29
May 7, 2015 08:27 PM
btbradley12
Aug 4, 2014 09:33 AM
Stevec
Jan 23, 2014 03:09 PM
slaughter442
Feb 4, 2013 04:08 PM
Charlie_brown
Feb 19, 2010 02:02 PM
