Intake leak?
Old April 7th, 2019, 03:00 PM
teamwieland's Avatar
Intake leak?
First pulls on dyno and oil leaks already starting. Hard to tell from pics but appears to be originating from where intake meets heads. Grey RTV looks good from outside and no seals used. Is this the classic intake oil leak location or could it be originating from heads?
teamwieland is offline
Old April 8th, 2019, 10:17 PM
cutlassefi's Avatar
Yes, you need to press in a dab at each corner, then lay the bead across the China rails.
cutlassefi is online now
Old April 9th, 2019, 06:04 AM
The intake-to-block and intake-to-heads mating surfaces are places where an oil leak can easily develop. Did you use the turkey tray intake gasket? I've never been able to get those gaskets to seal. I use the intake-to-head fiber gaskets and then ditch the rubber or cork end rails. Instead I liberally use Form-a-gasket on the end rails. I've never had intake oil or vacuum leaks since I ditched the turkey tray.
Olds64 is online now
snowri
October 29th, 2017 09:22 AM
Olds/uk455
April 14th, 2017 11:51 AM
olds330
November 29th, 2014 06:40 AM
1987425
August 4th, 2012 10:05 PM
oldsca
June 14th, 2010 05:46 AM
Quick Reply: Intake leak?
