Pushrod length
Old December 2nd, 2018, 05:05 PM
Big Features's Avatar
Pushrod length
Putting in a new cam and lifters and was told I can keep my stock non-adjustable valve train. Going through the pushrods, several have pits(some severe) and I want to replace them. What is the stock/standard size for a '68 G-block 400? I've seen several lengths listed as "stock" or
"OEM".
Thanks.
Big Features is offline
Old December 2nd, 2018, 07:51 PM
cjsdad's Avatar
If you have the valve train apart enough to see the pitting on your factory pushrods you should be able to measure them. You should install your new cam and lifters and see if they give you the proper amount of lifter preload before ordering new ones.
cjsdad is offline
Old December 3rd, 2018, 05:13 AM
Oldsmaniac's Avatar
A said there is a good chance you will need longer or possibly shorter pushrods. You want a slight amount of lifter preload when rockers are bolted down and both valves are closed. Too little or no preload and your rockers will be noisy.
Oldsmaniac is online now
Old December 3rd, 2018, 10:08 AM
^^^THIS!. Is the new cam a stock replacement or not? If not, does it have a reduced base circle? If so, that will require pushrods longer than stock to maintain the correct valvetrain geometry and lifter preload.
joe_padavano is online now
Jhucks03
May 26th, 2019 03:16 PM
Macadoo
December 3rd, 2013 10:15 AM
steverw
June 18th, 2013 10:17 AM
Creativeindy
October 4th, 2012 12:34 PM
rket56
October 20th, 2009 09:49 PM
Quick Reply: Pushrod length
