Need 69 400 STD Piston
Old Apr 30, 2019 | 09:01 PM
jphotrod's Avatar
Hey guys I'm kind of in a bind. I need a standard bore 69' 400 piston part # 398454. We tore down our 69' 442 today and the block is in great shape but one piston had a ring land broken. We're trying to freshen the engine up on a budget and a new set of pistons is out. The block is in near perfect condition so if we can find a piston we're going to just hone the block out. We only need one piston. If you have one that you could part with please let me know.
Old May 1, 2019 | 05:36 AM
67OAI's Avatar
Old(s)GuysRule
What is your location?
Old May 1, 2019 | 01:31 PM
jphotrod's Avatar
Northeast Tennessee
Old May 1, 2019 | 11:25 PM
jphotrod's Avatar
Apparently no one has a used one. Can someone tell me if and where I could by a single stock replacement? Supercars Unlimited sells the whole set but doesn't list them individually. Anybody?
Old May 2, 2019 | 04:33 AM
68442's Avatar
I will check my stash, I should have one if i can find them. Anyways, you will need to find an OEM factory piston nothing else will work, Anything new aftermarket/replacement would require the entire rotating assembly to be rebalanced which would defeat the budget rebuild
Old May 2, 2019 | 06:03 AM
Bob Kelso's Avatar
If you cant find one i will look at some i have . BOB
Old May 2, 2019 | 08:17 AM
501Paratrooper's Avatar
Egge machine
Old May 2, 2019 | 11:16 AM
DFisch's Avatar
pm sent
Old May 2, 2019 | 03:02 PM
oldolds88's Avatar
I have some for a 68 g block,
Old May 2, 2019 | 11:53 PM
jphotrod's Avatar
Thanks for the replies guys. I think I may have something coming. I'll update shortly. Again, thanks for everyone's responses.
Old May 12, 2019 | 08:22 AM
jphotrod's Avatar
Big thanks to DFisch for the help with my piston issue. At the machine shop now getting the hone done!
Jonquet1
Jul 28, 2018 10:08 PM
69 Vert
Feb 16, 2018 09:09 AM
67Rocket
Dec 16, 2016 09:09 AM
Bernhard
Jul 20, 2015 11:18 AM
getawaycar
Jul 13, 2011 05:13 AM
