Factory 400 G piston ?????????
Old Jan 21, 2015 | 05:38 PM
Bernhard's Avatar
I'm looking for information on factory 400 G pistons.
I thought I located standard bore 400 G piston for a 68/69 442.
But it turned out that the piston had a large dish.
I was under the impression that all 400 G blocks used the same piston.
The part number on the large dish piston was 399909 it also had GM cast into the piston.
If some one could post pictures of a factory 400 G piston that would be great.
Also if you could post the part number that would also help a lot.
Bernhard
Old Jan 21, 2015 | 06:29 PM
sammy's Avatar
Sammy70 455 Supreme
442 400G piston, 1968
398454....
Old Jan 21, 2015 | 07:04 PM
Bernhard's Avatar
Originally Posted by sammy
398454....
Awesome
Thanks Sammy
Is that a standard bore piston?
Would you be interested in selling the piston or pistons?
Old Jan 21, 2015 | 07:27 PM
69ho aurora's Avatar
Bernhard
All '69 400s used the same piston (except for the "letter" code differences for fitment). '68 was a different story. While most used the same high-compression pistons as '69, '68 also had the low-compression 2-bbl 400 in the "Turnpike Cruise" option. I had one of those in one of my 442 ragtops back in the day...
Old Jan 21, 2015 | 09:10 PM
Bernhard's Avatar
So I must have been sent 1968 turn pike cruiser 400 pistons
#399909 17.11cc
Sammy's piston looks much better
#398454 68 and 69 ??????
According to the NHRA all Hi comp pistons have a 1.70 cc dish 68/69
Also do you know how the letter code works???
I also found In the supper tuning book were they list factory numbers
#400618 W30 or W32 ?????????
Due you know were there might be a list of part numbers listed for the 68/69 G 400 pistons?
Thanks for the reply's
Bernhard
Old Jan 22, 2015 | 04:43 AM
allyolds68's Avatar
Supercars Unlimited lists a 10.5:1 standard bore piston for the 400G (as well as .030 and .060)
Item #: 14-018
Old Jan 22, 2015 | 05:01 PM
Bernhard's Avatar
Item #: 14-018
I need a original factory GM piston to have a copy made. C P will manufacture the piston, then they will be shipped to the NHRA for approval.
The NHRA will then keep the original piston and the cp piston for there recorders.
Old Jan 22, 2015 | 05:49 PM
Octania's Avatar
__________________
Defender of the 400 G
Well hell why didn't you say so
I might have one such piston if I can find it. I used to try to keep one of everything. You don't need a great conditon piston, just an example.
Old Jan 22, 2015 | 07:01 PM
Bernhard's Avatar
__________________
Thanks for the offer, sammy has some he will be sending me.
Old Jul 20, 2015 | 09:56 AM
sammy's Avatar
Sammy70 455 Supreme
Finally!
Pistons sent Bernhard........ummmmmm finally. Thanks for your patience
Ted
Old Jul 20, 2015 | 11:18 AM
Bernhard's Avatar
No Thank You
Very much appreciated
wr1970
Jan 23, 2015 10:36 AM
oldsmosteel
May 3, 2013 09:59 AM
L69
Nov 27, 2011 12:38 AM
sbFALL63
May 28, 2010 05:45 AM
