Olds 425 dementions
Old Sep 2, 2018 | 03:51 PM
RocketRonnie's Avatar
Olds 425 dementions
Online I'm getting the same numbers,sump, starter and oil filter placement as the 455. Is this true. How about the weight.
When picking out a 425 what should I consider.
Will I go wrong getting one from a toranado due to the fwd? What about the different can degree?
Thanks Guys
Old Sep 2, 2018 | 03:55 PM
In got for the 455.
Wide= 26.5
Tall = 31
Long= 31
Oil filter=right rear
Sump= rear
Starter = left side
Old Sep 2, 2018 | 04:08 PM
young olds's Avatar
As far as I know the cams are available, I think it’s just the larger lifters that are harder to come by. You still working on that 63?
Old Sep 2, 2018 | 04:16 PM
i ended up selling my 63's. Took that money and got a 65 skylark ht, then picked up a 55 Packard clipper ht for dirt cheap, and just last week I got 63 lesabre wagon. I'm thinking of putting an olds engine in the wagon and I've heard nothing but good stories of the 425. I don't know of you still have my # but send me a text so I can save your # again.
Old Sep 3, 2018 | 07:07 AM
The only differences between the 425 and 455 are the stroke, and the various combinations of lifter bank angle and diameter. Externally the two are identical.
Old Sep 3, 2018 | 08:12 AM
cutlassefi's Avatar
.921 lifters are now readily available.
Old Sep 7, 2018 | 10:00 PM
So does the 425 exhaust connect in the middle?
Will intakes for the 455 fit the 425?
And performance part too from the 455 too?
Does the 425 share the same oiling problems as the 455 in the top side of the engine during high rpms for prolonged time?
Old Sep 8, 2018 | 05:48 AM
If any of that stuff was different, I would have mentioned it in the sentence that started "the ONLY differences between the two..."
EVERYTHING ELSE is the same. Oil passages, port dimensions, etc,etc. As for this mythical "oiling problem", I've never seen it in nearly half a century of running these motors. What, exactly do you define as "prolonged" and "high rpms"?
Old Sep 8, 2018 | 10:28 AM
well that's real cool.. and about the oiling issue, im just going on what I've read in other forums. More good news if its a myth. Any engine would have issues if you held the rpms up high for long periods of time.
Old Sep 10, 2018 | 08:15 PM
Just picked up a 425 and a th400. Going to unload it and post pictures later
Old Sep 13, 2018 | 03:10 PM
Did all 1966 th400 from Oldsmobile come as variable shifts. Id is 0D-66-5252
Old Sep 13, 2018 | 03:13 PM
I don't know what "variable shifts" are, but if you are asking about the switch pitch torque converter, yes, all 1965-67 Olds TH400s were switch pitch.
Old Oct 1, 2019 | 09:18 AM
chief670's Avatar
check lifter size. mine is 2.125 tall,.920 bore. can't find lifter this size. 67 tornado 425 (Iowa motor)
Old Oct 1, 2019 | 03:20 PM
cutlassefi's Avatar
I have the .921 lifter in a roller or flat tappet.
RocketRonnie
Feb 9, 2019 09:51 AM
doggonn
Jun 29, 2018 06:14 AM
oldstoro66
Aug 31, 2017 08:28 PM
angelica
Dec 1, 2012 05:31 PM
sethj78
Feb 28, 2012 10:45 AM
