Olds 455 ring gap question
Old Aug 7, 2018 | 05:55 PM
EJC's Avatar
EJC
Ok, crank is torqued down with new ARP bolts to ARP spec. I have a set of KB277-60 pistons and cast Hasting rings 661 I believe. Top ring gaps are at .020 to .021 within Hasting gap spec but KB is showing .026 Hastings was .014 to .022 for there specs. Which way should I go?
Old Aug 7, 2018 | 06:22 PM
Trophyblue442's Avatar
You need to go with the KB specs. Those pistons hold a lot of heat and need a larger gap. Improper ring gap causes major problems with those pistons
Old Aug 8, 2018 | 05:55 AM
EJC's Avatar
EJC
Thanks, I noticed the KB rings have a moly top ring different from the Hastings rings I have. Do the specs for ring gap for the KB277 hold true for both ring types? Probably overthinking it but thought I would ask before putting it together. I try to live by the 6 Ps.
Old Aug 8, 2018 | 06:17 AM
cutlassefi's Avatar
Material is irrelevant other than for wall finish.
Old Aug 8, 2018 | 06:19 AM
EJC's Avatar
EJC
Perfect.
Thanks guys.
Old Aug 9, 2018 | 05:07 PM
BillK's Avatar
Just have to ask why on earth you would use a cast ring instead of moly ? That being said you definitely have to go with the KB specs on ring gaps. I usually add a couple of thousandths to that.
Old Aug 10, 2018 | 06:51 PM
EJC's Avatar
EJC
Ok, what ringset do you suggest? I see Hastings sell a chromemoly "coated" set. Researched KB but can't find the .060 rings on there site. Part number would be great.
Old Aug 10, 2018 | 07:02 PM
BillK's Avatar
Hastings 2M661 .060
Old Aug 10, 2018 | 07:05 PM
BillK's Avatar
I use the Hastings Moly rings in just about every naturally aspirated engine I build. They seat while on the engine stand as long as the cylinders are finished correctly and last forever.
Old Aug 10, 2018 | 07:07 PM
EJC's Avatar
EJC
My math says .027 for the top ring gap. You mentioned to open them up a few more thou though right.
Jhucks03
Apr 5, 2019 05:40 AM
pogo69
May 19, 2014 01:50 PM
OLDSmobility
May 13, 2011 07:47 PM
sx455raidercelticfan
Jan 13, 2011 05:05 AM
dman0712
Apr 13, 2010 06:38 PM
