do they make 455 60 over steel piston rings??
Old Jan 11, 2011 | 03:58 PM
sx455raidercelticfan's Avatar
hi every1 ive been searchn and searchn and i cant find 60over 455 piston rings with a steel top ring, can some1 please point me in the right direction
thank you
Old Jan 11, 2011 | 04:50 PM
geckonz08's Avatar
thank you
try these guys --pricey though
http://www.flatlanderracing.com/pringsolds.html
Old Jan 12, 2011 | 06:19 AM
507OLDS's Avatar
The manufacturer of your pistons should have a ring set available,or the company that does.
Old Jan 12, 2011 | 06:59 AM
cutlassefi's Avatar
I agree with Brian. Whether it's a 5/64 or 1/16 ring they should be readily available. It's a very popular bore size.
Old Jan 12, 2011 | 08:52 AM
the rings that cam with the pistons are cast, i just decided 2 go with plazma molly but the top rings not steel they said its a strong medal that starts with a D, im a little about my original block sealing all i did was break the glaze because its allready 60 over, ive read that steel rings seal better in my situation, my fingers are crossed!!!
Old Jan 12, 2011 | 10:11 AM
507OLDS's Avatar
Are you thinking of a ductile iron ring?
Old Jan 12, 2011 | 08:02 PM
BINGO!!!!!! thats it!! they said its alot stronger than cast but not as strong as steel and it should seal up fine after 50 miles or so
Old Jan 13, 2011 | 05:05 AM
cutlassefi's Avatar
Yes ductile iron is a good ring but that's not what will necessarily make it seat in 50 miles or so. If it's a moly coated ring with the right wall finish then yes but otherwise there's no gaurantee it'll seat that quickly.
Do you need a full set or just the top rings?
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
cutlassefi
Nov 28, 2013 12:08 PM
auto_editor
Jul 10, 2011 11:20 AM
wildwillie1981
Mar 28, 2010 06:09 PM
Kwish
Jan 30, 2010 09:03 AM
