Click Here
245/60/14 Will they fit & how will they look?
Old April 10th, 2011, 11:39 AM
442b's Avatar
My 72 442 has a set of 225/70/14's on it presently. I want to put 60's on the car so I'm looking at BF Goodrich 245/60/14's.
Does anyone have these tires on their car now & can share some info like will they rub the fender wells when turning, Rear wheel wells, any problems with them at all?
I don't want to change wheels which are Factory SS II's & I don't want to put 15's on the car.
Thanks for any help.
442b is offline
Old April 10th, 2011, 04:58 PM
svnt442's Avatar
Look here. Scroll down and click specs
http://www.bfgoodrichtires.ca/tire-s...dial-t-a-tires
svnt442 is offline
Old April 10th, 2011, 05:03 PM
extreme1's Avatar
keep in mind those tires will be about 2.5" shorter than stock diameter ( I have the same tires on my '72) so your speedo will be out. Right now the tires you have are a bit shorter than stock already as I believe the modern tire size equivalent should be 215/75R14.
extreme1 is offline
Old April 10th, 2011, 06:59 PM
stevengerard's Avatar
That's what I have and many others have, no issues at all except for speedo adjustment if need be.
stevengerard is offline
Old April 11th, 2011, 10:32 AM
NorCalSS's Avatar
not sure if it helps but i have 215/60/14 on my 72.
NorCalSS is offline
Old April 11th, 2011, 01:09 PM
As others have pointed out, the 245/60-14s are significantly smaller in diameter than the original tires. Your call on whether you like the look or not. Personally I don't care for a lot of "daylight" between the tire and the wheel opening. 225/70-14 is about as close as you can come today. 235/60-15s are similar but require 15" wheels.
joe_padavano is offline
Old April 11th, 2011, 02:34 PM
442b's Avatar
Ok Joe, how about a taller 60/14? I could go with a 225/60/14 or a 215/60/14 which both tires would mount on the 14" x 7" wide Stock SSII wheels that are on my car.
442b is offline
Old April 11th, 2011, 02:40 PM
svnt442's Avatar
Both of those will be SHORTER, not taller than a 245/60/14. Look at the link I posted and you'll see what I'm talking about.
svnt442 is offline
Old April 11th, 2011, 03:11 PM
442b's Avatar
Yeah, forgot about your link. I was going by what the guy at Tire Rack had just told me on the phone. He said, bigger number, shorter tire height. I guess he was wrong. Thanks
442b is offline
Old April 11th, 2011, 03:13 PM
svnt442's Avatar
He was actually talking about the second number. The way a tire size breaks down is like this:
245 = section width in mm, NOT tread width.
60 = aspect ratio. What that means is the tire is 60% as tall as it is wide.
14 = rim diameter.
I hope this helps.
svnt442 is offline
Old April 12th, 2011, 07:39 AM
Unfortunately, 245/60-14 is about the widest 14" tire that's commonly available today, but are very small in diameter as compared to the original tires on A-body cars. 14" tires are hard to find in general anymore unless you pay big bucks to a company like Coker for repros.
As an example:
245/60-14s are only 25.5" in diameter.
225/70-14s are 26.5"
225/75-14s are 27.3"
235/70-14s are 27" but are very difficult to find.
Old April 12th, 2011, 08:54 AM
442b's Avatar
Well, I placed my order & chose to go with 235/60/14. Cost was less & size was about that of the 245/60/14. Time will tell, once they arrive I'll get them mounted.
442b is offline
Old April 12th, 2011, 09:29 PM
fourtwenty's Avatar
With the 235's when your speedo says 60 you will actually be doing 56.4 mph
fourtwenty is offline
Old April 12th, 2011, 10:00 PM
Ben
RAMBOW's Avatar
you would have been happier with the 245/60's
on a 14" rim, the smaller sizes really look small. 245/60 is a nice wide tire without looking like a balloon like a wide 70 series tire would.
RAMBOW is offline
Old July 3rd, 2020, 10:02 AM
Edward Alvarado's Avatar
P245 60 14
As an example:
  • I have 245 60 14’s on my 70 El Camino they fit good in the wheel wells and look great but ya they are pricey now. In the late 80’s were about $95
Edward Alvarado is offline
pappanick
October 18th, 2014 08:32 AM
February 15th, 2014 08:18 PM
REOLDS
July 22nd, 2012 07:08 PM
oldzy
Wheels and Tires
November 23rd, 2011 04:37 PM
Jayycobb
Wheels and Tires
October 25th, 2011 10:34 PM
Quick Reply: 245/60/14 Will they fit & how will they look?
