What you guys think
Old Jan 13, 2011 | 09:48 AM
sicky olds's Avatar
NôôB
What you guys think
So with the seize of my engine and thinking about doing a rebuild, me and the guys did a little googling and ran across this article:
Olds 455 Buildup
tell me what you guys think or things i should change or what not.... AND GO!!!
Old Jan 13, 2011 | 12:36 PM
alek72us's Avatar
Olds Dreamer
It looks good but if i was to use those heads i would do a better more high compression piston. you will get more out of it that way.
if u use those pistons u will be better off using steel heads, aluminum heads like more compression.
Old Jan 13, 2011 | 01:27 PM
sicky olds's Avatar
NôôB
what heads would you suggest then? and i think i am going to keep the cam i have in the car also, it has less intake but more exhaust i believe:
Specs on cam in it now:
Cam Grind No.: 280/250H-10
Intake/exhaust
Duration at .050: 230/235
Lobe Lift: .310/.315
Lobe seperation: 110
Seat Duration @.005: 280/285
Gross Valve lift: .496/.504
Valve Lash (Hot): 0/0
Degree intake lobe to: 106 ATDC
Hope people know what this means cause it was a lot to type lol
Old Jan 13, 2011 | 01:36 PM
alek72us's Avatar
Olds Dreamer
You will be happy with any big valve head. what heads do u have now? there are alot of c heads on craigslist for sale.
Someone else will have to chime in on the cam. i dont know much about them.
Old Jan 13, 2011 | 01:53 PM
RAMBOW's Avatar
Ben
Intake/exhaust
What heads do you have now? What is wrong with them?
Just rebuild your bottom end..Fix whatever broke. If you don't already have good pistons, then Pick good pistons that will put you around 9.5:1ish (w/ iron heads) then go enjoy it.
You have to remember most magazine articles are basically ads for the magazines key advertisers, so take their build choices with that in mind.
Not saying their build didn't put out the power they say it does... just saying you can do it for a lot less w/o using fancy stuff.
You need to know what heads you have now(or what heads you want to run), and what pistons you currently have.
once you know that, then the other build options can be calculated.
Old Jan 13, 2011 | 01:55 PM
sicky olds's Avatar
NôôB
I have C-heads on the car right now. will have to check the receipts i have to find out to see what pistons and such is on it.
Old Jan 13, 2011 | 01:58 PM
firefrost gold's Avatar
what do you want to spend? I would go with a roller cam and have the c heads ported. what intake do you have?
Old Jan 13, 2011 | 02:55 PM
cutlassefi's Avatar
O.K. here goes, I have a set of Ga heads for sale, 2.07 intakes, all new valves, guides, seats, and springs, $650.00 plus shipping. Springs would have to be changed if you went with a performance cam.
You have to figure out your budget first, then decide how much or how little hp you can live with. And if you go with good heads get a cam with more lift to optimize your build.
Jmo.
Old Jan 13, 2011 | 05:29 PM
sicky olds's Avatar
NôôB
@ firefrost: i have the edelbrock intake in this build i believe. i know its an edelbrock but not sure what model
Old Jan 13, 2011 | 06:14 PM
alek72us's Avatar
Olds Dreamer
well it sounds like u have the heads and intake, so just depending on ur pistons u dont need much. unless u want alot more out of it. so u need to decide what u want out of it and what ur budget will allow.
Old Jan 13, 2011 | 06:25 PM
alek72us's Avatar
Olds Dreamer
Also have you tore down ur old engine yet. i think there is alot of people curious wondering what happen.
Old Jan 13, 2011 | 07:30 PM
BIGJERR's Avatar
I bleed Oldsmobile
Just a note........
You were talking about reusing your cam and or more parts......
If you spun a bearing and the shavings from afore mentioned bearing got run across the cam,Thru the lifters etc....its junk
Tear that hurt motor down and see what is reusable.......
Maybe my combo is a over achiever but with the TRW slugs and a decent port job it went 11.66@114mph on the motor shifting at 5800 and weighing in at 4000 lbs........
Combo http://72.22.90.30/phpBB2/viewtopic.php?t=12112
Old Jan 14, 2011 | 04:39 AM
sicky olds's Avatar
NôôB
no i am ordering the engine stand today and i am not sure how long it takes for summit to ship it to texas. if i was back home i would already have it lol
citcapp
Sep 11, 2019 11:02 AM
steedaq
May 1, 2010 06:03 AM
Hark442
Body work
16
Oct 2, 2009 04:02 PM
