They don't make them like they used to....thank God!
Old Nov 23, 2013 | 06:19 AM
cutlassefi's Avatar
I've contended for the last few years that the way I have my blocks machined via the BHJ fixtures is better than most on here and other places.
Let me explain further.
Currently I have 2 Olds Big blocks at the machine shop I use in Jacksonville Florida. 1 is a 425 "D" block, the other a 455 "F" block.
Both blocks were sonic checked first, with similar results. That is done at 12, 3, 6, and 9 o:clock as being viewed from the side of each bank. Then it's done at the top, middle and bottom of the cylinders. But in the interest of time and space I will only describe one of the worst of the 8 cylinders on the D block. Block was ultimately bored to 4.180.
Sonic check results, cylinder #4, top to bottom;
12:00 286-263-254
3:00 153-145-139
6:00 291-276-305
9:00 218-200-191
Obviously the 139 is the limiting factor for overbore as you typically don't want any less than .100 on any non thrust side (front or back wall of cylinder)
However the BHJ Bor-Tru plate http://www.bhjproducts.com/bhj_conte...ntfixt/btk.php used correctly locates the bore over the journal and perpendicular to the crank after the block has been align honed and square decked. This cylinder on this block was out .023 front to back, (heavy on the rear) and .020 side to side (intake to exhaust side). Therefore it would take no less than .046 to clean up (from standard by the way) and correctly locate the cylinders in the block. Hence one of the reasons it had to go to 4.180.
So during boring it actually took much less off the front (3:00) than the rear. If someone was going to bore this as "big as they could go" they would have been limited by the 139. As it turns out this block could have gone to 4.210 and beyond with little or no issue after correctly locating the bore as most of the meat came off of the rear (9:00).
And needless to say correctly locating the cylinder over and perpendicular to the crank has it's advantages. The angle of the bore in the block side to side as being viewed from the front is also corrected. This one was out .008 top to bottom.
So now in this case the bore is more centered in the casting. Others have said that these blocks may exhibit "core shift". But here the core was right, however it was bored incorrectly at the factory, by a bunch.
Does core shift happen? Of course, but until it's machined correctly with the right procedure and equipment there's no way to tell for sure where the discrepancy lies. If someone were to favor the "heavy" side without really knowing what was what they could actually be making it worse.
Hope this helps.
P.S. By the way, some machine shops tout a CNC program to machine their blocks. However they use the location of the deck dowels as a reference. Read the text on BHJ carefully. They mention that their plate allows for the correct location of the dowels as they're not always in the right spot from the factory. If you use the dowels as a reference point, and they're off, then so is the rest of your machining process, plain and simple.
Old Nov 23, 2013 | 06:27 AM
Run to Rund's Avatar
Thanks.
Old Nov 23, 2013 | 07:11 AM
Yes, very interesting. Thanks, Mark.
Old Nov 24, 2013 | 05:29 PM
Charly9g's Avatar
Great info!!! many thanks!! i'm about to start on a '455 build and this will come in handy.
Old Nov 24, 2013 | 05:56 PM
dc2x4drvr's Avatar
Old Nov 24, 2013 | 06:19 PM
oldsmobiledave's Avatar
thanks
Excellent post. Thanks for sharing.
Old Nov 25, 2013 | 05:40 AM
cutlassefi's Avatar
You're very welcome, thanks guys.
Both of these are full builds which will be going to the dyno. Of course I'll post the results.
Old Nov 25, 2013 | 08:52 AM
cutlassefi's Avatar
Here's the results of the sonic check. Sorry it loaded this way, tried twice to correct it.
Old Nov 25, 2013 | 10:07 AM
Here ya go:
Old Nov 25, 2013 | 01:31 PM
cutlassefi's Avatar
Thanks Eric.
One note, as per the text, notice the wall thickness on #4 and #6 vs #3 & #5. Notice how much more concentric 3 and 5 are at 3:00 and 9:00 especially.
Obviously one side was better than the other. I find that a lot.
Old Nov 25, 2013 | 02:07 PM
allyolds68's Avatar
That's great info Mark.
I'd personally like to see you take the high road and leave other vendors names out of it though.
Old Nov 25, 2013 | 02:32 PM
cutlassefi's Avatar
I see your point, and I somewhat agree. I will change it.
But the reason I mentioned it initially is because some don't know to ask those types of questions when enlisting the services of a machine shop, any machine shop. So I hope this helps.
Thanks.
Old Nov 25, 2013 | 02:36 PM
61reoldsman's Avatar
Mark you do make excellent posts I must say ,very informative !
Old Nov 26, 2013 | 01:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
So let us use me as an example, my block needs to bored and honed to 4.395 from 4.351". So if I tell them to just over bore it, most will take even amounts from either side, where my block might have significant core shift? This means potentially running too thin wherever the bore shifted? Sounds interesting and important.
Old Nov 26, 2013 | 02:33 PM
cutlassefi's Avatar
Yes, I've run into that before. Once you see how far off it is sometimes you just have to make do with what you have or look for another core.
Old Nov 28, 2013 | 09:51 AM
O.P.LARRY's Avatar
Mark you must REALLY hate BTR.Just because he will not give you free advice on cams anymore.....LET IT GO MAN.All you are really doing is hurting the
OLDS community with you're constant bashing of Bill.
I don't have the time to de-bunk your BS,but I will be back.
Old Nov 28, 2013 | 11:46 AM
cutlassefi's Avatar
Huh? I don't HATE anybody!
He says his CNC program is the way to go(there are other shops that claim the same, I didn't single out anybody), I don't believe it is and I showed why.
I've talked to Bill more than once, just not recently, no need to really, no issues. He also did my buddys crank, it's in his book. Again no issues.
I think you misunderstood my point(s).
Old Nov 28, 2013 | 12:08 PM
Yeah, I didn't see anything particularly "hateful" in anything Mark posted either.
He just contrasted different techniques, and noted that the basis for claims that the other one is superior is not solid.
Mark doesn't even bore his own blocks, so it's not like he's trying to get business for himself this way either. He's just giving information about what he has found.
76olds
Feb 18, 2015 02:54 PM
DewChugr
Brakes/Hydraulic Systems
Oct 14, 2014 07:33 PM
Hotrod-Youngster
Apr 10, 2014 06:00 PM
auto_editor
Jul 10, 2011 11:20 AM
Col Wickham
Nov 24, 2009 04:48 AM
